November 28, 2024, 04:51:33 AM *
Pages: 1 [2] 3 4   Go Down
Author Topic: Fairing stiffener post  (Read 10438 times)
S2R 800 '07
« Reply #15 on: April 23, 2016, 04:50:13 PM »
Just throwing out ideas while we're waiting for the man  waytogo
https://traxxas.com/search?type=All&keyword=rod%20ends&items_per_page=40&page=2
Online Online
« Reply #16 on: April 23, 2016, 04:59:52 PM »
I think you're going in the wrong direction.
It needs to be waaaay better looking.
« Reply #17 on: April 23, 2016, 10:49:35 PM »
A little more searching turned up this good effort by blalor.
Sadly, I'm too new to understand the humor of previous posts popcorn
My EZ pass is stuffed between the windscreen and the gauges.  This seems to stabilize the fairing quite well.
S2R 800 '07
« Reply #18 on: April 24, 2016, 01:34:08 AM »
Of course - that link shows us that very clearly  Cool
S2R 800 '07
« Reply #19 on: April 24, 2016, 12:08:14 PM »
I now have a lead on drawings for these.
If Monsterlover can do them, we're closer  coffee
Eric@S2R8
« Reply #20 on: April 24, 2016, 12:16:52 PM »
Wow! that's great.  applause
If that doesn't work, I've found that searching for a right angle ball joint produces some fittings that could work at the top mount. http://www.amazon.com/Strut-Thread-Socket-Bracket-Mount/dp/B00WI08IHW?ie=UTF8&psc=1&redirect=true&ref_=ox_sc_act_title_1&smid=A1THAZDOWP300U
Our top mount on the fairing has a 5mm (0.80mm pitch) button head x 15mm long. The bottom mount uses a 6mm (1.25 coarse pitch)  x 20mm long.  There’s about a 7” span between the screws.
I think a ball joint with the female end going to the fairing, and the male end screwing into a hollow threaded rod about 6 inches long, to either an eyelet, or another ball joint at the bottom end.
I'll wait to read of any better plans.
« Reply #21 on: April 24, 2016, 01:33:21 PM »
Maybe a list of highly motivated buyers is in order.
S2R 800 '07
« Reply #22 on: April 24, 2016, 01:48:45 PM »
I'll ask him tomorrow and if he's interested/willing I'll put up a poll thread. (poll answers are cheap and means little, but it's a start)
The best kind of whore is a
« Reply #23 on: April 25, 2016, 08:04:18 AM »
Someone send me drawings and I'll have a look. The stays in the first pic are killer
Kevin at southmorgan dot com
S2R 800 '07
« Reply #24 on: April 25, 2016, 08:06:35 AM »
Coming up  waytogo
Online Online
« Reply #25 on: April 25, 2016, 08:41:01 AM »
Have you sourced cf tube?
Who's going to assemble?
Jig for aligning the ends on the tube?
S2R 800 '07
« Reply #26 on: April 25, 2016, 09:15:12 AM »
Carbon rod or tube, but maybe just as well aluminum?
Mine are broken, so not much use as templates. Maybe they could be a three piece design - put together when mounting and glue if desired.
« Reply #27 on: April 25, 2016, 10:07:37 AM »
Did some digging.
CF tube is readily available as are red anodized rod ends (though I didn't see any that were *exactly* like what was in that first picture)
Personally, I think threaded aluminum or titanium or stainless would be cool.  At least in the event of a crash you could reuse the rod ends, replace the bent tie rods and be back in business.  Glued CF tube and your just screwed for reusing the ends.
But then again, I love the look of threaded rod with locknuts and rod ends.  Industrial Grin
Most of the threaded rod I found has a ton of thread exposed, which I don't like.  If it were my bike, I'd take some aluminum rod and thread each end RH/LH only a little extra beyond what I'd need to make any adjustments.  That way the majority of the rod is just a round rod vs exposed threads and it would look extra bad ass.
But that's just what *I* like.
I'll machine it however my customers want it.
Eric@S2R8
« Reply #28 on: April 25, 2016, 10:57:58 AM »
You guys are bad@ss!
 Cool
The nice thing about reverse threads and locknuts at each end is that it then becomes like your shifter -  you can fine-tune the length to make small adjustments in the fairing height.
Metal or carbon fiber rod, but with metal, you can use Loctite instead of glue.
Online Online
« Reply #29 on: April 25, 2016, 11:03:57 AM »
I'm pretty sure Chris...Statler...had those on his S4RS. I think that's his bike in the pic.
I might be able to get a length for the rod from him so Kev could thread some rod. that would make it a DIY kit...which would be awesome.
Let me know if you guys want me to get in touch with him.
Pages: 1 [2] 3 4   Go Up
