November 04, 2024, 02:34:26 PM *
Author Topic: Torque Spec SSS pinch bolts - I am definitely getting weaker in my old age  (Read 1529 times)
dbran1949
2007 S4RS Black Termis
« on: May 05, 2016, 10:22:36 AM »
Anybody know what the Torque Specs are for the eccentric pinch bolts for an 07 Monster S4RS? I have always had this done with regular servicing at the dealer in San Diego, but now I have the bike up in Portland OR while consulting on a project up here and can't find a good time slot to get it into the dealer up here.
I thought this would be pretty straight forward but when I went to loosen the bolts I was unable to. Is this normal - I was using a 3/8 drive ratchet (gear wrench) which has a fairly long handle. Is it typical to have to use a 1/2 inch breaker bar on these things?
Thanks
Dan
« Last Edit: May 05, 2016, 10:43:45 AM by dbran1949 » Logged
« Reply #1 on: May 05, 2016, 10:31:21 AM »
You should not have to use a breaker bar. I don't remember the specs, but that's over-tightened...
S2R 800 '07
« Reply #2 on: May 05, 2016, 01:36:22 PM »
+/- 33 Nm
If there isn't enough grease, they can be hard to turn.
dbran1949
« Reply #3 on: May 05, 2016, 02:19:18 PM »
Would it be ok to put a little penetrating oil on them - there is no corrosion but they are very dry
S2R 800 '07
« Reply #4 on: May 05, 2016, 02:30:02 PM »
To loosen them, I guess so.
« Reply #5 on: May 05, 2016, 02:45:40 PM »
Yes, penetrating oil is OK.
Don't get it on your brake disk.
S21FOLGORE
« Reply #6 on: May 05, 2016, 04:48:35 PM »
The manual says
 33 N-m (24 ft-lb.) in 1-2-1 sequence.
(The manual also says apply “Grease B”. Grease B is molybdenum disulfide grease, any CV joint grease will do fine. I use this one. You can find them at NAPA.)
« Reply #7 on: May 05, 2016, 04:57:05 PM »
Very brave to put a tube of grease on a white bathmat.
« Reply #8 on: May 05, 2016, 05:24:29 PM »
I'd cop a rolling pin to the head at my joint for doing that. Grin
