October 01, 2024, 04:25:02 PM *
Author Topic: All I wanted to do was adjust my chain tension - need advice  (Read 1477 times)
dbran1949
2007 S4RS Black Termis
« on: May 14, 2016, 04:29:24 PM »
So first I had to go out and buy a 24" long 1/2" breaker bar to loosen the pinch bolts on the eccentric. I did get them loose then carefully backed them off a little at at time. They did have what looked like molybdenum disulfide grease on them so I have no idea why they were so difficult to loosen. Earlier I ordered  a   http://motowheels.com/i-9377332-corse-dynamics-non-slip-eccentric-ducati-chain-tool-large.html   CORSE DYNAMICS "NON-SLIP" ECCENTRIC DUCATI CHAIN TOOL. My fault it did not mention the 2007 S4RS in the details section - but it had a 2008. I figured they would probably be the same, evidently not the tool is too big and won't grab the eccentric.  Does anyone know the correct tool. I have a feeling this thing is going to be tough to turn so I need something that really fits well. Not sure why this thing is being so uncooperative any suggestions on the correct tool.
One more thing - since I was having trouble seeing what was going on I decided to remove the mini "chain guard" what a PITA. one of the little 8mm bolts was pretty easy (the one in the back) but the front one was a nightmare took almost 1/2 hour turning a little box end wrench a 1/4 turn at a time. Awesome design
thanks
« Last Edit: May 14, 2016, 04:32:20 PM by dbran1949 » Logged
Enjoying the ride
« Reply #1 on: May 14, 2016, 05:01:19 PM »
Sorry to learn about the incorrect tool, the correct tools are these:
http://www.monsterparts.com/pc/CH-1/Maintenance/CH-1.html
http://motowheels.com/i-9377333-corse-dynamics-non-slip-eccentric-ducati-chain-tool-small.html
and even better,
http://www.motomfg.com/Ducati_tool_package_Ducati_wheel_nut_tool_p/tc-2.htm
I think if tool is NOT marred or scarred, Motowheels should be able to send you the correct one or something of the same value . ..my 0.02
dbran1949
« Reply #2 on: May 15, 2016, 08:41:07 AM »
Thanks!
I don't know why I didn't see the correct tool on corse dynamics. I will get back to them since when I ordered the incorrect tool there is a section of the order where I put the model and year of the bike. However I do think it was my fault as the 07 was not on the list in the details and I ordered it anyway
I have looked for how-tos on this, can't find anything very clear. Do you know which direction to turn the eccentric to tighten the chain?
« Reply #3 on: May 15, 2016, 09:02:52 AM »
Should be counter clock wise to tighten.
« Reply #4 on: May 15, 2016, 09:05:33 AM »
Usually it's rotate CCW as viewed from the left side of the bike to tighten.
Motowheels shanked it on both the description and details for the large unit.
It says it will fit S4Rs, and it will not fit.
Charlie98
Marveling at my
McKinney, TX
« Reply #5 on: May 15, 2016, 05:08:09 PM »
I think I got the wrong one, too, for my 796.  bang head  I just haven't had time to do anything about it.
Dennis
2013 M796 ABS
blalor
« Reply #6 on: May 16, 2016, 02:42:51 AM »
I found the bolts to be surprisingly tight on my S2R, as well.  The adjuster moved quite easily, however.  I have the motomfg adjuster and it works well.  (Unrelated: i have their sockets, too, and don't like them. I don't think the front axle alignment tool is necessary.)
