January 15, 2025, 10:35:39 AM *
Author Topic: New from Bmore  (Read 1348 times)
rwiggins32
« on: May 19, 2016, 07:26:57 PM »
Hey fellow Monster owners!
I'm a little late to this site. I picked up a used 2012 796 ABS last August and I'm in love with it.
I joined this forum to pick up some ideas for cosmetic and performance mods. It came with Leo Vance pipes and frame sliders, I added an Evotech Fender Eliminator. I'm open to suggestions, feel the message me or direct me to a thread.
Thanks
Charlie98
Marveling at my
McKinney, TX
« Reply #1 on: May 20, 2016, 05:12:53 AM »
Welcome!
Depends on what you want to do with it... it sounds like it's pretty well squared away as it is.   waytogo
Dennis
2013 M796 ABS
rwiggins32
« Reply #2 on: May 20, 2016, 08:38:15 AM »
I want to work on the low rpm range drivability. I've here power commander  or ecu flash are the way to go. Any options?
Sent from my SM-G930V using Tapatalk
Charlie98
Marveling at my
McKinney, TX
« Reply #3 on: May 20, 2016, 03:04:42 PM »
Then you and I are on the same sheet of music.  As the bike comes, it is too lean for good bottom end.  Personally, as soon as I get a set of cans for it (the Leo Vince are on my short list) I have a 2nd ECU I bought off eBay to have reflashed... and also get rid of the O2 sensors/flapper and help the throttle response.
I'm curious... yours already came with aftermarket exhaust; I wonder if the previous owner had the ECU reflashed already?
You said you are in Baltimore?  In my past life I used to dispatch gas trucks in the B'mo area (primarily 7-11 and Costco) along with Virginia and northern NC.
Dennis
2013 M796 ABS
« Reply #4 on: May 20, 2016, 03:44:06 PM »
Welcome chug.
Post in Tech with questions on that. Also there should be a fair bit of material in the search function.
rwiggins32
« Reply #5 on: May 21, 2016, 06:38:35 AM »
Thanks, I'll try that
Curmudgeon
« Reply #6 on: May 22, 2016, 12:37:01 PM »
You could always start with a 14T front sprocket as many do. The one for 796 is specific BTW. Sponsor Monsterparts has them among others. Then take it from there.  Cool
rwiggins32
« Reply #7 on: May 22, 2016, 12:38:07 PM »
Thanks!
