January 08, 2025, 07:29:25 PM
2005 S2R good year?
Topic: 2005 S2R good year? (Read 1654 times)
jvax
in the land of the rising sun
2005 S2R good year?
July 01, 2016, 03:37:17 AM »
Hi folks.
Looking at a black 2005 S2R with 21000km clocked, pretty much bone stock, for about $4000. Good deal?
Any particular issues with the 2005 MY?
'08 R1200GS
'10 M796 ABS Black (Sold)
Re: 2005 S2R good year?
July 01, 2016, 06:24:27 AM »
Price depends a lot on condition, so hard to tell from here.
The usual plastic tank issues.
Fairly common for the fuel pump wiring to fail.
Front brakes aren't particularly flash, but can be improved with pads.
jvax
July 01, 2016, 09:53:24 AM »
Quote from: Speeddog on July 01, 2016, 06:24:27 AM
Fair enough. Thanks anyway.
No issues with the fuel where I live.
Good to know about the fp wiring. Will ask the seller.
Thanks again.
'08 R1200GS
S21FOLGORE
July 02, 2016, 12:08:44 PM »
I have one. And love mine.
I think 2005 models have steel tank. (Mine is steel.)
The only time I got stranded on this bike was when regulator/rectifier died.
(Otherwise, it has been 100% reliable.)
Sooner or later this is going to happen, unless R/R is reloacted to the place where it gets air flow, or R/R has been replaced with MOSFET unit.
2004, 2005 S4R(996), especially in bone stock trim, has tendency to do bucking bronco in lower rpm (below 3,000 rpm).
(There’s a way to cure.)
A lot of fun on the twisty back road.
Not so much in the heavily congested city traffic. (Due to the roughness of low rpm range AND heavy, less forgiving dry clutch action.) (Again, there’s a way to cure about the clutch.)
July 05, 2016, 08:30:55 AM »
Quote from: S21FOLGORE on July 02, 2016, 12:08:44 PM
Interesting. I had a 2005 S2R800 and mine was definitely plastic...
The Architect
July 05, 2016, 10:52:32 AM »
Some of the 2005's came with metal tanks and some didn't. And some of the bikes came with an o2 sensor and some didn't.
If you can find one with a metal tank and no o2 sensor, I would consider buying one.
http://www.livefreeballistics.com
July 05, 2016, 11:03:32 AM »
I've not seen an '05 S2R800 with a steel tank (from the factory, anyway).
'05 S4R had the steel tank.
S2R1000 started in '06, all I've seen have plastic tanks.
July 05, 2016, 12:07:36 PM »
Quote from: The Architect on July 05, 2016, 10:52:32 AM
I believe that was the 620 Monster, not the S2R.
