Swap S2R800 in 1100 EVO
Started by BuckA, July 22, 2016, 08:18:46 AM
BuckA
Hi guys.
I need some advice.
I swap my engine on Monster S2R800 2005 in Monster 1100 EVO 2012 engine. And make custom exhaust. Also i think to change injectors on 280.4.023.1A from 1100 evo.
What do you think about ecu? What ecu will be better for me? I don't want change electric wiring if it posible.
Read all about it here  [thumbsup]
http://www.ducatimonsterforum.org/index.php?topic=59229.0
exhaust
Power Commander III with a custom Dyno map
another gear under the flywheel
should be it...
Dirty Duc
The cam teeth are different on the EVO from the 800.
Your ECU options are:
EVO ECU (Siemens?) - Wiring involved to adapt to S2R chassis
800 ECU - Magneti Marelli with custom map (stopintime linked it)
Standalone with Ducati wiring (e.g. Nemesis)
Standalone with custom wiring (e.g. Microsquirt)
It all depends on your wallet size and skill set or willingness to dive into the deep end. :D
Dirty Duc
Quote from: Dirty Duc on July 22, 2016, 08:42:43 AM
Sticking with the MM ECU, you also have to swap the layshaft gear under the left side cover. The custom map part comes because the cam sensors are in different locations... I think that caused HeMan's tuner no end of trouble.
