Question to those with gsxr forks
Started by caperix, July 23, 2016, 06:01:09 AM
caperix
I am looking to upgrade the forks on a 695 on a budget.  All the gsxr fork threads I can find upgrade to the 320mm rotors at the same time. Has any one tried to keep the factory 300mm discs? 2004/2005 gsxr 600 shows to use 298mm 0mm offset rotors like the smaller monsters. They also seem to use the same fork center distance of 207mm.  So in theory if you stay with this year fork setup the stock 695 wheel and brake rotors can be used.  Can anyone confirm this info?
