September 04, 2024, 08:16:41 PM *
News: Please Help
Author Topic: Q about replacement voltage regulator  (Read 1657 times)
Ddan
Some of my best friends are whores
« on: July 19, 2008, 05:50:39 AM »
Does anyone know how I would install the R/R from a '98 996 into a '92 SS?
This is the SS with stock hook-up:
The regulator is on the right of the pic.
According to the wiring diagram, the 2 solid reds go to the battery +, white w/ red trace goes to the charge indicator, small red w/black trace goes to the fuse block
This is the 996 hook-up:
« Last Edit: July 19, 2008, 07:41:57 AM by Dan » Logged
                    flogged successfully  NHMS  12 customized.  Twice.   T3 too.
Ducati Monster Forum at
www.ducatimonsterforum.org
clubhousemotorsports
« Reply #1 on: July 19, 2008, 05:42:23 PM »
Yellow to yellow
red to red (top wire in your photo)
green to ground
the rubber plug on the wiring harness should get sealed/capped off. you will no longer have a battery light. this rectifier does not use a sensor line for the regulator either.
better get it going trackday is on its way [moto]
Ddan
« Reply #2 on: July 19, 2008, 07:04:54 PM »
Cool, thanks.  waytogo  I'm almost ready, timing is retarded as far as it will go, exhaust is ready for packing; once  that's done I'll synch and adjust the carbs and it should be  set.
