Clutch adjustment? Or new plates?
Started by Hollisatp1, August 26, 2016, 10:55:33 PM
Hollisatp1
Hey all. I'm newer here. My clutch has started to slip a bit when I throttle fast. Is this an adjustment or is it time for new clutch plates?
How many miles on the plates? Also what are you using?
I meant to ask what oil are you using?.
Hollisatp1
21,500. Using full synthetic 10/30. Just changed oil about 300 miles ago.
Hollisatp1
It is definitely slipping. When I give gas fast I can feel it slipping then catch.
Oil can be your cause, specifically if it is energy conserving.  Was the clutch slipping before the oil change?  Changing oil to a motorcycle specific oil that has JASO MA on the label.  If oil is your problem it may take more than one oil change, or, if bad enough, new plates, so you might want to try cheap non synthetic oil first.
Curmudgeon
Quote from: howie on September 04, 2016, 04:49:48 AM
[thumbsup]
