January 01, 2025, 08:40:19 AM
Please Help
M695 Wiring Flaws
Topic: M695 Wiring Flaws (Read 3474 times)
cencalal
M695 Wiring Flaws
September 06, 2016, 06:53:20 PM »
Mama mia Luigi! Whatsa with the capelli d'angeli wiring inna my Mostro? I just finished repairing another broken wire to my rear lighting, due to the thin gauge of the wire - don't know how long I've been riding around with no brake light. Most of the wiring seems robust enough, and is sheathed and zip tied securely, and has nice weatherproof metri pack connectors. But when I hooked up my mosfet regulator a few months ago, I noticed that the yellow wires were on the thin side, and that connector, which really should be weatherproof, was not. So I'm wondering what other flaws in my wiring I might want to fix before I find myself by the side of the road, cursing Gabriele Del Torchio.
Any tips on wiring fixes or upgrades for the 695?
cencalal
Re: M695 Wiring Flaws
September 07, 2016, 06:17:35 PM »
Hmmm, no takers...well, here's one for you:
Looking in from the right, (no airbox) the bundle of wires from the ignition switch (top, left of center) that has just emerged from the bottom of the switch housing, makes a head fake left to where it's zip-tied to another bundle, then cuts back across to the right side of the frame (lower right) and then crawls back to the left side along a frame tube, where it enters an unsealed snap connector zip-tied to the front of the tube. This is one of the critical connections, and it's just hung there facing into whatever spray might be there. And it takes a foot of wire to cross the frame twice, just to get to where it started. I'm ranting here, right?
I'll be revising this one.
Feral 859
September 07, 2016, 06:30:50 PM »
You can read through this thread for some thoughts. Not a 695, but same nest of wires.
http://www.ducatimonsterforum.org/index.php?topic=69859.msg1290101#msg1290101
d3vi@nt
September 07, 2016, 08:03:39 PM »
Quote from: cencalal on September 06, 2016, 06:53:20 PM
Might try paging suzyj if she's still around, or at least check out her threads. Here's a great one:
http://www.ducatimonsterforum.org/index.php?topic=56614.0
'13 MTS GT
'99 ST2
'07 M695 - Sold
September 07, 2016, 09:14:53 PM »
I must point out that Kopf's boy possesses world class wiring skill.
And suzyj's skill-set is the most astonishing I've seen in my life.
Their work is indeed inspirational.
cencalal
September 07, 2016, 09:22:44 PM »
Those are some great looking projects, guys - thanks for the links. I'm just looking to fix the worst of it, though - replace the unsealed connectors etc, and tidy it up a bit.
Feral 859
September 07, 2016, 09:47:00 PM »
Once you start tugging on one of them little wires, it never stops.
Enjoying the ride
September 08, 2016, 06:01:29 AM »
Quote from: kopfjäger on September 07, 2016, 09:47:00 PM
what he ^^^ said
cencalal
September 08, 2016, 06:19:09 AM »
I could do a fantastic job like Kopf and Suzy - I've done it before...in my dreams!
Enjoying the ride
September 08, 2016, 06:34:19 AM »
Quote from: cencalal on September 08, 2016, 06:19:09 AM
WAKE UP WAKE UP . . You're late for work
cencalal
September 09, 2016, 07:43:47 AM »
In the photo above, the bottom two wires entering the connector (coming from the ignition switch, white/red stripe, and blue) don't come out the other side. It's six wires in and four out, and the two unconnected wires have no voltage when the key is on.
I'm replacing this connector - should I just use a four pin connector and just wrap these two wires? I suppose this is just a case of Ducati using the same wiring on other models? And what amp rating would be needed for this connector?
Last Edit: September 09, 2016, 05:17:12 PM by cencalal
JohnEE
Why not
September 12, 2016, 05:07:09 AM »
The wiring diagrams are available online if you really want to dig deep. Last page of the owners manual.
http://www.ducati.com/services/maintenance/index.do
08' S2R 1000
SpikeC
Spike in PDX
September 13, 2016, 03:59:03 PM »
What is Italian for Lucas?
Spike Cornelius
PDX
2008 Bimota DB5R woo-Hoo!
1965 T100SC
September 13, 2016, 05:10:42 PM »
Quote from: SpikeC on September 13, 2016, 03:59:03 PM
Capt Obvious here...
Ducati?
Wasn't Ducati an electrical manufacturer originally?
ducatigirl100
Reply #14 on:
September 24, 2016, 07:03:25 PM »
Quote from: cencalal on September 09, 2016, 07:43:47 AM
Just make sure those 2 wires (white/red stripe, and blue )may be jumps together so the wiring can work.... I've seen this a couple of times in ducati wiring .....
Also that conector dosen't look OEM to me ......it looks like a connector you get a the local electronic shop....
Last Edit: September 24, 2016, 07:08:15 PM by ducatigirl100
