Exhaust studs - 97 M900
Started by greenohawk69, September 15, 2016, 12:23:19 PM
greenohawk69
Have some rusty studs, with one nut rusted to a stud.
Going to replace all four studs. Do I need to replace with the exact same kind? By this, I mean, do I need to have a "middle shank" of ~ 7mm or can I replace with a fully threaded  (socket cap) stud?
Also, any sources other than the dealer?
"An enlightened people, and an energetic public opinion... will control and enchain the aristocratic spirit of the government." --Thomas Jefferson to Chevalier de Ouis, 1814
There are 4 boxes to be used in the defense of liberty:  Soap, Ballot, Jury and Ammo.  Please use in this order.  -- Ed Howdershelt
The only thing that you have to watch out for with a fully threaded stud is installing too deep in the head and damaging the heads or having the stud stick because it's bottomed.
Nibor
Also, can't be too tall poking out of the block, otherwise you'll have clearance issues trying to fit the exhaust components, on the studs inside the exhaust bend. Trust me, I know  ;)
I ended up replacing with OEM, using plenty of anti seize.
clubhousemotorsports
Another vote for oem. You might be able to find generic studs from an industrial supply but you will probably need to buy a bag of them. I doubt there is any cost savings worth the trouble so if it were mine I would order up some oem parts.
I was not aware that Nichols sold exhaust studs, only cylinder studs.
