January 01, 2025, 08:35:10 AM *
Pages: 1 [2]   Go Down
Author Topic: ELECTRICAL CONNECTORS  (Read 3383 times)
ducatigirl100
« Reply #15 on: September 24, 2016, 07:25:03 PM »
Thanks!  What I have to connect are the two 14 or 16 ga main wires and two 22 ga lighting relay wires.  Can I use one connector for those different size wires?  If so, it's a four-way.  I was going to use a metri pack 280 two-way 30 amp for the big wires (those don't seem to come 4-way), and some sort of mini connector for the lighting wires...
Seperating the 2 types of wires is a good idea if they have a complete defferent purpose.  Considering ...4 or 16 awg  and 22 awg  hare really far apart......      but you can use a 4 way conector bit you will have to use the corresponding cripms...
The quation is more where those wires feed the power ?
« Last Edit: September 24, 2016, 07:26:49 PM by ducatigirl100 » Logged
cencalal
« Reply #16 on: September 24, 2016, 07:31:14 PM »
If I'm reading the wiring diagram right, one of the small wires (orange) connects to a lighting relay, and the other (yellow) goes to a little lamp in the headlight.  Using separate connectors, one big and one mini, seems the way to go...
« Last Edit: September 24, 2016, 07:38:13 PM by cencalal » Logged
Pages: 1 [2]   Go Up
