ELECTRICAL CONNECTORS
Started by cencalal, September 15, 2016, 07:15:28 PM
cencalal
I'm replacing the connector at the bottom of this photo:
I need to find a 4 conductor weatherproof connector - metripack or similar - for 14/16 ga wire.  Took a look on ebay, where they go for between $1.50 and $30.  ??? How much do I need to spend for a decent connector, and where is a reliable source?
Thanks
Dirty Duc
Langanobob
The guy at
www.easternbeaver.com
specializes in connectors and has a good reputation although no FHE.
He is in Japan and has a $20 minimum order so best to find several things you need.
SpikeC
 I believe Eastern Beaver is in Canada now.
Spike Cornelius
  PDX
2008 Bimota DB5R  woo-Hoo!
   1965 T100SC
bdfinally
SpikeC
Spike Cornelius
  PDX
   1965 T100SC
danaid
I had a good experience with this company when I bought a headlight harness connector.
http://www.cycleterminal.com/index.html
The owner quickly answered an email question I had and gave me several choices for higher quality connectors.
11' 1198SP  Black
09' 1100S    Red
ducatigirl100
I use Deutch connnectors on all the electrical loom that I've made in the last years .... very hi-quality...
I suggest getting a kit but you can also order them by items
https://m.delcity.net/store/Deutsch-Compatible-AT-Series-Connector-Kit/p_799834
The Deutsch stuff is excellent.
cencalal
Thanks for all the suggestions - no problem now finding a connector.  The stock unsealed connector has 7mm wide blade terminals.  It's big. The red and red/wht wires are 14/16 gauge and carry power to and from the ignition switch - will a 30 amp rated sealed connector, like a metri pack 280, be adequate in that position?  The bike's main fuse is a 30 amp...
ducatigirl100
The metripack will work fine for you application .....  the only things is that ther bulky .... the Deutch connetors look better ...
I use metripack for linking the alternator to the voltage regulator...  I'ts probeblly the hardest voltage and harsh condition that you can put a connector  true...and it works flawlessly...
ducatigirl100
I have a box full of metripacks.... if you want I can send you  everyting that tou need to install it ( crimps, plugs, receptical )
Whit metripack you just have to dont forget to put the little ruber first , crimp the wires and after intall it in the plug or receptical ..... the order is important .....
A 4 way connector is that it ?
P.m. your adress and I send it to you.......free.....   [thumbsup]
cencalal
Thanks!  What I have to connect are the two 14 or 16 ga main wires and two 22 ga lighting relay wires.  Can I use one connector for those different size wires?  If so, it's a four-way.  I was going to use a metri pack 280 two-way 30 amp for the big wires (those don't seem to come 4-way), and some sort of mini connector for the lighting wires...
