December 29, 2024, 09:42:12 AM *
Author Topic: Help with New Suspension Setup  (Read 1779 times)
metzy
« on: October 01, 2016, 07:09:22 AM »
Finding the ride on my 2007 M695 quite stiff and thinking of upgrading my suspension setup.
What would be a suitable rear shock based on 98.5Kg body weight?
How about the front shocks?
Ideally I'd like to do a straight swap out with minimal frame modifications.
Will be sourcing from eBay as I live in Asia, (specific part numbers would be awesome!)
Really appreciate some recommendations/advice.
Sent from my iPhone using Tapatalk
« Reply #1 on: October 01, 2016, 08:04:19 AM »
Please turn off the iphone/tapatalk advertisement.
The adjustable Showa forks from '00-'02 M900, '01-'02 S4, M1000, S2R1000, and any non-testastretta S4R are a good start.
Then properly sprung for your weight, 0.90 or 0.95 springs.
Rear shock from '01-'02 S4 is a direct bolt up, and is a bit better.
Again, sprung for your weight, Ohlins -39 or -41.
Or generic 650 lb/in spring, for example:
http://www.traxxion.com/Shock-Spring-Hypercoil-7-x-650lb-x-225/
ST4s came with an Ohlins shock, that'll fit, but you'll need to find a suitable mounting area for the reservoir.
« Reply #2 on: October 01, 2016, 02:08:50 PM »
http://www.ducatimonsterforum.org/index.php?topic=73379.msg1351052#msg1351052
metzy
« Reply #3 on: October 03, 2016, 05:06:18 AM »
Awesome, really appreciate your help @speeddog
Didn't realise Tapatalk notifications was on, been though the settings so hopefully sorted that out now.
metzy
« Reply #4 on: October 03, 2016, 05:45:08 AM »
I found this 2002 S4 rear Sach on eBay for a reasonable price, do think think it will fit @Speeddog https://www.ebay.com/itm/122138214315
« Reply #5 on: October 03, 2016, 07:17:27 AM »
Yes, that'll bolt right on.
Get a proper spring on it before you go to the effort of installing.
metzy
« Reply #6 on: October 06, 2016, 05:44:38 AM »
Brought the rear shock @Speeddog now trying to source a spring.
Found these 2004 ST3 https://www.ebay.com/itm/141899672522 will they fit my beast?
« Reply #7 on: October 06, 2016, 07:50:11 AM »
They will fit your triple clamps and axle and brakes, but are only adjustable for spring preload.
And there is a possibility they are too long.
I'd ask the seller for an overall length, compare to yours, fully extended.
