S4RS tricolore full brembo, borrani rims, clear belt cover, ceramic coated
Started by teedee brown, October 07, 2016, 08:56:49 PM
teedee brown
Hi guys,
Here is a short preview of my S4RS.
Did some mods but haven't finish yet projet is still on going
Everything as started when shit happened and decided to do an overhaul.
I will post some more pics later but you can start by watching this short preview
Everything is possible it only depends on your wallet thickness!
Nottsbiker
Ducati Monster 900 (project) Aprilia Tuono 1000
Desmoss
 [clap]  [Dolph] [beer]
..you get covers from Stephen, Australia!!???
We want pic of spoke wheels  :'(
teedee brown
Yes Desmoss i got the cover from him
here is some pics of the bike when i got it then when all started the accident day
teedee brown
Here is the preview of the borrani rims
teedee brown
Then i started to debuild the bike until became a tamiya model scale 1/1  ;D ;D ;D
pitbull
Can't wait to see your bike back together.
The S4Rs is the dream bike for me and the only other bike I want to go along with my old 01 900.
teedee brown
Once i dismantle everything
I did the 24k servicing, belt, valve clearance, coated the pulley and adjusted the timing as i had to remove the pulley, change some o-rings and hardware and of course a bit of cleaning
Mhanis
The front wheel took a hell of a shot!
Keep up the good work!
Mark
Pete Townshend
Desmoss
Hy Teedee....
How about transparent covers....did you put some kind of gasket,rubber anything under it???
Also ,how about some kind of "rubber washers" under the bolts???
I am asking you that so that vibrations are reduced and not to cause cracks or something else on covers!!???
Unfortunately my bike is parked in garage last 2 years because of absence!! However,till now I install only lower cylinder cover and after few rides I found small crack on the part where is bolt!!!
teedee brown
Actually mine cracked already just when i tighten with a torque wrench at 10nm
So too late already but will consider the rubber washer
Anyway still some work to do
I just received my exhaust from ceramic coating and fitted yesterday
SAL
Sorry for the newbie question but where did you get that front fender? Id like same in CF for my Tricolore.
THNX.
