900ss 92mm ring set
Started by Pinion, October 11, 2016, 04:01:46 PM
Pinion
so am I to understand it cost just about as much for a set of rings an a set of aftermarket pistons.
Or can someone help me out on a source. taking rings off to tidy up pistons and one broke. poop
Will trade toilet paper for parts
You understand correctly.
Maybe someone else that's done the same can help.
Was it the oil ring?
Pinion
na, 2nd ring. dont want to go through the hassle of high comp, crank balance, revalve ect. motor ony has 6k on it
Quote from: Pinion on October 11, 2016, 04:20:25 PM
It's usually the oil ring that hurts people.
Someone has a ring somewhere.
Pinion
http://www.ebay.com/itm/Ducati-900SS-Stock-Pistons-Rings-Covers-/172357560173?hash=item28214fa76d:g:rtIAAOSw-kdX1Xct&vxp=mtr
bunch of stuff you don't need, but it will solve your issue for short money.
I have a used piston with rings, but I wouldn't sell it for that price.
clubhousemotorsports
Did you notice the ebay add listed the parts as "900SS" parts?
Clearly they are from a monster, buyer beware when buying from Ebay.
What piston and cylinder do you have A , B or C spec. you will see it stamped on the piston top and cylinder. If you get a replacement ring be sure to measure ring end gap because the cylinder spec refers to different sizes.
What year 900?
What piston (A, B or C)?
part number on bottom of piston?
Pinion
#8
yes, beware of ebay, and I have a 900ss motor, that besides a few minor differences, looks just like an m900 and aslo my 11k motor pistons look just like those "low Mileage" ones, lol.
Feracci has a drop in high comp set of pistons, may just go for it. I'm gonna call them today to chat with them about it
thanks ducpainter
Quote from: clubhousemotorsports on October 12, 2016, 06:23:16 AM
What year 900?
I know about the A,B,,,C?
Other than that, how much difference is there in 900 pistons between year and models?
Pinion
pre 96 intake valve size. mines a 95 bigger intake valve
Ha...I knew they changed in ~98 when they went to the W heads, but I didn't know there were larger intakes than the V heads.
V = 43mm, W = 41mm.
Dont know if they used the same piston and valve reliefs. Anything bigger than 43mm aint stock.
Perhaps there's some 900's that came with forged pistons, some with cast.
My 750 has forged slugs, as it clanks rather alarmingly when it's cold.
Pinion
pistons are fine, I snapped a ring taking them off to clean piston.  [bang]
