Anyone ever used a brembo remote reservoir master cylinder with ATPC?
Started by ljsmonster, November 27, 2016, 10:38:19 AM
ljsmonster
I've got a 2005 620ie Monster with ATPC and would like to change the clutch master cylinder to one off of a 2004 S4R.  Would this be possible?  Any thoughts would be appreciated!  [thumbsup]
Should be no problem. The master works with the slave to disengage the clutch. As long as you use the same bore size it will accomplish the task.
ljsmonster
