September 03, 2024, 06:23:29 PM *
Author Topic: Removing ride height rod?  (Read 1437 times)
« on: July 20, 2008, 08:51:48 AM »
Can the ride height rod on the s2r1000 be easliy removed?
Mine seems to have frozen up and now I've buggered up the bottom "nut" trying to get the adjuster to move.
OverCaffeinated
« Reply #1 on: July 20, 2008, 09:22:40 AM »
FYI the bottom adjusting nut is a left hand thread. You would turn it clockwise to loosen it. I wouldn't say removing the whole rod is easy. You have to figure out a way to support the rear of the bike in the air, to take weight off the suspension. I used a forklift at my job, which worked great cuz I could move the bike up and down to remove the bolts. Good luck.
« Reply #2 on: July 20, 2008, 09:29:18 AM »
The nuts are loose no prob, the rod won't turn.
Hedgehog
« Reply #3 on: July 20, 2008, 09:32:09 AM »
I don't know how well this works on other models, but here are a couple of pics of a stand I made for my SS to hold the bike while I do rear suspension work.  The rod is a piece of drill rod from a metal dealer.  I believe it's 5/16".
OverCaffeinated
« Reply #4 on: July 20, 2008, 09:57:16 AM »
I've heard of this happening. Ducati doesn't put any antisieze lube on the threads. So after time and heat those bolt become one with rod. If you haven't already, try sprayin some Nuts Off or PB Penetrant and let it soak a bit. I can understand how it is hard to get enough leverage without messeing stuff up in that tight space.
uclabiker06
"The time you enjoy wasting isn't wasted"
« Reply #5 on: July 21, 2008, 09:51:05 AM »
Quote
Yeah I've heard of this happening too.  The easiest way to support your bike is to use a car scissor jack with a 2X4 between your tire and your frame.  The bottom bolt for the rod is the same rod that secures the shock just take your rear brake master out of the way, unscrew the bolt, then use a pair of needle nose pliers to retrieve it from inside the swing arm.
2006 S2R
2009 Smart
