Waste of money .....
Started by MonsterHPD, December 09, 2016, 08:30:02 AM
Sorry - can't remember, but think a small amount off stock.
Larger intake valves under the quite aggressive 900i cams were ok with two types of high comp Pistal. One pair had to be machined down - the dome diameter reduced - to avoid excessive compression. Also; another washer under the spark plugs to avoid contact.
