oil pressure question
Started by 673monster, March 23, 2017, 05:24:10 PM
673monster
My 2000 900ie is putting out 70psi at idle...should I be worried about a plugged passage somewhere?
IMO, no.
Per the manuals, 87psi is the maximum you should ever see.
Your 70psi, is that cold, hot, ???
673monster
70psi cold...haven't warmed it up yet...just got it all assembled.  When revved it goes up to 90ish
You should be fine, but report back on hot pressure at idle and 3k rpm or so.
EEL
What oil viscosity are you running? 20w50 or 10w40?
20w50 will result in higher heat, higher oil pressure and lower mpg.
Peruse the oil sticky for additional info.
673monster
Running 10-40w.  I'll wait and see what the pressure drops to once it's warm.
