Reservoir Cap Screws
Started by supasye, May 03, 2017, 06:43:19 AM
supasye
I've been looking all over for the answer to this question because I really did not want to resort to asking it here... :(
I need to replace the screws on my cluth and brake reservoir caps (ducati 695). does anybody know the size of the screws?
thanks.
EEL
if its a 695 you have coffin reservior caps correct? I had an S2R800 in the past and I remember those were flat counter sunk philips head screws that were fairly small.
Probably an M6 but just go the hardware store and get a couple of metric
EEL
Also the caps from what I remember were threaded through bottom of the reservior. Which means they didnt need a special length. Worst case get a longer screw and use a hacksaw to cut it to length.
M4x0.7 flat head phillips, 12mm overall length.
It's a standard diameter and pitch, so available at most good hardware stores.
You can upgrade to stainless, allen, or both.
supasye
thanks,
normally I would have just gone to a hardware store and figured it out myself, but I'm living as an expat in Korea and sometimes the simplest things are complicated!
