that Old Tangerine Dream (problem bike these days... :( )
Started by MsTek, June 01, 2017, 06:46:42 AM
MsTek
Quote from: stopintime on August 08, 2019, 02:27:17 PM
[thumbsup]
They wouldn't accept a return and refund?
Ask Chris at CCW if he will take your part in (part) exchange for a new and correct?
Good idea.  Thanks.
"Do something each day that scares you..."
MsTek
Good luck  [thumbsup]
The assembly video from Chris CCW shows how the connector is put together. Not difficult.
New video of the work when completed?
MsTek
A few more questions:
The battery is a li-ion one so should be charged up in about 3 hours.
Does this look right?  The wires are just loose in the gasoline?:
Is this caswell?:
Yep, the wires just hang out in the gasoline.
I try to route them through/around stuff so they're not too free to dangle around and fatigue.
Also makes getting the whole assembly back in a bit easier, that's usually only an issue on the small oval fuel pump plate units though.
MsTek
Quote from: Speeddog on August 16, 2019, 01:31:49 PM
Thank you.
I'm so nervous that it's not going to work.  I keep looking at the battery charger.  I want it to hurry up and I also don't want it to in case I am disappointed.
In the assembly video it looks (I can't hear the audio) like the flat spade goes on top of the pump and the round eye connector on a fuel filter clamp....
The tank inside looks like mine did before Caswell. Caswell comes in a clear version, plus colors, so it COULD be coated.
MsTek
Quote from: stopintime on August 16, 2019, 01:54:41 PM
I can take it out again. I put in the bike already.  I couldn't tell from the video that shows you how to do it what was going on with that.
Sorry, didn't completely understand the questions.
Will BRB with annotated pics.
MsTek
I still don't understand where this one goes.  Nor do I have any tiny screws in the box.  This is as s2r if Tha means anything.
Quote from: MsTek on August 16, 2019, 02:38:19 PM
That one goes to the fuel filter.
If you don't have the hardware, go to a hardware store, Lowes, Home Depot...anywhere, and get what you need.
MsTek
what size is that screw, do you know?
I am screwed. I can't drive my car to the hardware store.  Shit.
What size screw?  Maybe I have a screw from one of my computers I could use.
MsTek
i just found a tiny screw.  it doesn't look right but I will try it
