Oil sensor on an 2005 s2r800
Started by Norwayfreddy, June 17, 2017, 12:55:00 AM
Norwayfreddy
Hi
Im having problem with my oil sensor after plugging it out when i change timing belts. The display only shows ----
Do i need to restart something? Only bad connection? I change the exhaust and ecu at the same time, does that effect it?
Most likely a bad connection.
The wire fitting has to slip on to the head of the sensor.
The oil pressure connector, by the belts, is connected to the ECU.
The ---- in the display is from, or in this case NOT from, a bad connection under the clutch cover/oil sight glass.
Heia Norge  [thumbsup]
Jeg skjønte at du ville hilse på ham på norsk [thumbsup]
Norwayfreddy
Fixed [thumbsup]  thanks
Only bad connection ;)
DuciD03
.... all the world is yours.
