Brakes? Who needs them....
Started by Tenshikurai, July 21, 2008, 08:02:46 PM
Tenshikurai
So, I seem to have a bit of trouble with the rear brakes on my bike.  The brake lever won't come back up, the rotor is scorched, and visibly warped.  The caliper is a total loss, hot enough the pistons were starting to melt and mushroom against the brake pads, and the anodizing is very discolored.
Needless to say, I need a caliper and rotor.  As to the root of the problem I'm about to tear it apart and see what I find.
'02 620 w/900 swap, high compression pistons, lightweight flywheel, TPO beast intake, TPO clutch kit, and a few minor custom touches ;-)
truckinduc
mine has never worked. It wont return either. Im looking for a better design when i buikd my new rear sets. Good luck. Im curious to see what happened.
Hedgehog
You didn't happen to change the brake lever height sometime in the recent past, did you?
Tenshikurai
Not since August last year when I changed the brake lever.
Likely you had the brake adjusted such that the pushrod was too far into the master, and the piston covered over the bleed port.
This effectively seals the system.
Using the brake heats up the fluid, and it expands slightly.
This increases the pressure on the pads, so more heat.
And so it goes, until something gets hot enough or the pressure high enough that something fails.
I've got a BrakeTech iron rotor and Ferodo SinterGrip ST pads with OEM caliper and master on my S4, and it works very well.
The stock stuff can be made to work.
Tenshikurai
Hedgehog hit on the head.  I tore it apart last night, and the jamnut for the lever adjustment seems to have vibrated off, allowing the adjuster bolt to loosen up and force the brake lever down.  It must have been doing it a little at a time, as it didn't seem like the brake was dragging at all until I got up to highway speed.
So, time to check ebay for a used caliper, pick up a wave rotor, and some good pads.  I'd planned on a brake upgrade this fall, but I guess I'll do the rear half a bit early. ;-)
Norm
Quote from: Norm on July 23, 2008, 10:36:12 AM
What's a "rear" brake?
its used to make a sCREEECHCHCHCHH-ing sound when your stoping hard. otherwise useless
Actually, they're quite useful, if you take a little bit of time to set 'em up right.  [roll]
canes
Well speeddog, I'm gonna dance with ya [evil]
Other than draining the brake fluid out of the system, how do you set up a rear brake?
NEVER GIVE UP !!!!!!!
Norm
Oops, my son was still logged on to my computer. It's me speeddog.
Jarvicious
I normally use my rear more often than the front for everyday riding.  The engine does most of the braking for me, just use the rear for little speed adjustments here and there.  The front is just for the heavy duty stopping in the twisties and such.
Good luck with the replacement.  It's a bit disconcerting, but I often look forward to these little bike foibles as an excuse to upgrade, so enjoy!
DrDesmo
Quote from: Speeddog on July 23, 2008, 01:08:23 PM
Yes, what's the best way to set up for replacement rear sets to accomodate?
Thanks!
Adam
'95 916
'12 800XC
