V4 Stradale
Started by Speeddog, September 07, 2017, 09:57:08 AM
Quote from: Dirty Duc on September 12, 2017, 10:41:53 PM
I doubt a loss of torque... It should sound like nothing else:
It's only rated at 88.51 lb-ft of torque...
Dirty Duc
You're going to miss a half a ft/lb off the 1198? And that's more than a panigale chart a quick Google search picked up...
With a given displacement, you can only get so much twist. You do get (with an unlimited budget) to choose the rpm and curve... I bet this has a smoother delivery and more area under the curve.
http://desmosedicistradale.ducati.com/en_ww/datasheet/
"More than 120 Nm (88.51 lb-ft) from 8,750 to 12,250 rpm*"
Which means more than 147 HP at 8750rpm, and more than 206 HP at 12250rpm.
Dirty Duc
Quote from: Speeddog on September 13, 2017, 10:18:41 PM
Yowsa.
Not sure what he's doing, but he's sure got it sideways.
Kopfjäger
duccarlos
Dirty Duc
Quote from: duccarlos on December 11, 2017, 07:03:40 AM
This doesn't sound like any V4 I've ever heard. Did he confuse it with this one:
https://www.ducati.com/ww/en/bikes/panigale/1299-panigale-r-final-edition
It's the offset crank. Kind of like how a cross-plane R1 is the only sexy-sounding I4.
And when he pans over the top triple, it clearly says V4 Stradale...
Kopfjäger
Kopfjäger
GK
I agree they need to make the cost of Ducati ownership cheaper.
I noted one Persia's comment about valve springs replacing Desmo.
Dropping rubber belts for chains and Desmo for valve springs would surely lower service costs! Seriously, 32 shim checks on a V4! Yikes!
2001 Ducati  Monster 900S ie
Gone but not forgotten!
M821/1200 are 18k miles on valves, 18k/5 yr on belts
899 Pani, V4 Pani are 15k on valves, never on belts
MTS1260 is 18k miles on valves, 18k/5 yr on belts
For many first owners, that qualifies as never.
GK
Well you make a fair point. Those are certainly long intervals.
