S2R Rear Bearing Replacement
Started by RB, September 08, 2017, 06:08:46 AM
RB
I am trying to locate the rear wheel bearing for an 06' S2R, and have found bearing number SKF-BAH0062 in some other thread(can't remember where). I have 35K miles on the clock and need to replace this bearing before my trip to Deals Gap. I tried searching this forum before I posted but couldn't find any information specific to the S2R(i think the S4R's might be identical). Memory is IZ_, but I seem to recall reading that there are a few bearings that can be replaced in the eccentric. The parts manual does not show any bearings, only the entire eccentric....BS.
Short form...
What are the rear axle(eccentric) bearing numbers for an '06 S2R?
Thanks for the help and sorry if this is a redundant post.
RB
From an old document I have:
SKF BAH 0062 double row angular contact ball bearing (maybe not listed and has to be ordered by a (bearing?) dealer?)
Torrington NK42130A
Don't know if this helps....
RB
Thanks, for the reply. That bearing is like hens teeth in the states.
RB
#4
thisw is a bit old, but I am just getting to finishing this project.
Here are the part numbers for the rear wheel bearings and seals replacement for the SSS eccentric:
  • 2x SKF 6007, OR,  1x SKF BAH0062, double row bearing.... drive side
  • 1x NK42/30,  OR, TAF425230-IKO, needle/roller bearing 30mm.... wheel side
  • 2x Seals OAS-42X52X4-NBR.... wheel side bearing seals
I bought an entire kit from Ducati Mondo on fleabay....
https://www.ebay.com/itm/Eccentric-rear-hub-full-refurb-bearing-kit-for-Ducati-Monster-S2R-800-05-07-06/150976015226?
DuciD03
#6
good info; note I took the liberty of posting in
Re: Alternatives to expensive Ducati parts
« Reply #177 on: 19/07/2018 at 08:22:35 AM »
s2r 06 wheel bearing mining of info as per quote!   [thumbsup]
[Dolph]
Quote from: RB on July 19, 2018, 05:01:10 AM
.... all the world is yours.
