December 28, 2024, 05:04:25 PM
Adjustable Lowering Footpegs
Topic: Adjustable Lowering Footpegs (Read 1146 times)
KIKH400
September 27, 2017, 11:59:23 AM »
I've thought about getting adjustable footpegs, so that I could lower my pegs a bit and rotate them a little forward. I can't see any way to do this without having to get a new shift lever and brake lever. If I just lower, I may be able to adjust the shifter. The rear brake lever looks like it'll need to be replaced with something.
Am I right or am I missing something? If its going to require replacing my shift and rear brake levers, I'm probably not going to try this.
Thanks
S2R 800 '07
Re: Adjustable Lowering Footpegs
September 27, 2017, 12:11:19 PM »
Can you tell us which result you want? Knees/hips/ancles?
The lever replacement/modification depends on your shoe size. Also, a direct gear lever (GP style shift pattern) could solve that side. Brake lever is another story, but maybe it requires welding...
