Paddock stand bobbins M750?
Started by gentlemanjim, October 30, 2017, 08:32:22 PM
gentlemanjim
I see them advertised, but where do they mount?
Kopfjäger
One of the guys here that's well versed will know for sure, but I believe (?) only the aluminum swing arms were drilled out for the bobbins. I have no idea the years.
kopf is correct.
I suppose you could drill and tap, but there wouldn't be enough material thickness for me to consider them.
A better solution would be a threaded insert, IMO.
The best solution is a rear stand that doesn't use bobbins.
gentlemanjim
cayman s
Quote from: kopfjäger on October 30, 2017, 08:58:31 PM
[/quote
Spools were welded to the aluminum swingarms of some bikes at the factory, like on my M900.
https://www.dropbox.com/preview/IMG_1720.JPG
The hollow aluminum swingarms were not drilled for factory or aftermarket spools.
Harps
Wow, came here to ask just this question...thanks!  Unfortunately, my M750 is a "have not" :(
JEFF_H
M750s didnt come with alum swingarms
Pit Bull makes an insert that you can drill/add to your swingarm to mount the bobbin
