February 21, 2025, 08:14:07 AM *
Author Topic: S2R / S4R tank and pump question  (Read 2437 times)
hillbillypolack
« on: November 25, 2017, 03:45:52 PM »
I wanted to ask a general question on the fuel pump arrangement / performance and reliability of the S2R vs S4R fuel pumps.
Most probably know the S2R is a circular base which has both the fuel pump and quick disconnect fuel lines.  The S4R has all that as well, but was also used on 848 / 1098 etc superbikes. . . .so. . is the oval version any more reliable than the round base S2R?  I am assuming there could be a difference in pump pressure due to demand for 4V vs 2V engines.
Last, I have an S2R.  Would it be at all possible to fit an S4R tank onto my S2R?  Only asking since I'm wading through the fuel pump and fuel tank issues, and considering any possible 'upgrade path' while I have things torn down.
Thanks in advance
Dirty Duc
I'd rather be an anti-
« Reply #1 on: November 25, 2017, 03:49:34 PM »
Afaik, all stock bikes (except the race homologation SBK Rs) ran the usual 43.5 psi fuel pressure. The pumps appear to be the same.
« Reply #2 on: November 25, 2017, 04:56:29 PM »
I've noticed zero difference in reliability of the different flange styles.
Everything except the wiring is very reliable in my experience.
Converting between steel and plastic tanks is costly, as almost none of the components are shared.
S4Rs/t plastic tank is smaller capacity than S2R tank.
hillbillypolack
« Reply #3 on: November 26, 2017, 07:41:23 AM »
Thank you - that’s the info I was looking for. I had a hunch that the S2 & S4 pump ‘plates’ were the main difference but I’m not able to compare them side by side.
I’m talking with a company that makes aluminum  fuel tanks. They’re familiar with the S4 version. No, it’s not a cheap conversation so I wanted to ask ahead of time if there is a benefit for the oval S4 design.
Dirty Duc
« Reply #4 on: November 26, 2017, 07:48:07 AM »
Cost and availability might be a consideration. It seems the round flanges go for a lot more money on eBay. $600 compared to $200 or so.
chipripper
El Borracho mas grandisimo
« Reply #5 on: November 27, 2017, 12:01:07 PM »
I thought I read somewhere the S4r used an oval to make more room for the extra stuff (airbox etc.) under the tank? Maybe why the S4r holds less fuel? I'm only guessing as I have the S2r.
2008 S2R1000 black and white, mostly stock ;-)
Marving header, Velocity stacks, Pod filters, Flashed ECU to DP map, Polished valve covers and cam covers, SSR reverse shifter and inspection cover, Aelle adjustable pegs, Windscreen and cowl removal, Many plastic bits removed, Cut beer tray
« Reply #6 on: November 27, 2017, 01:23:13 PM »
Yes
Derekv
« Reply #7 on: December 03, 2017, 09:29:27 AM »
I have a 2005 S4R with a metal tank.  Is the metal tank stock?  What year did they switch to plastic?
Derek V
2005 S4R
« Reply #8 on: December 03, 2017, 10:12:38 AM »
Derek V
Yes. First year S4R had a steel tank from the factory.
Derekv
« Reply #9 on: December 09, 2017, 08:34:11 AM »
Thanks!
2005 S4R
booger
« Reply #10 on: December 09, 2017, 12:16:38 PM »
Yes
 Huh?
Both S2R & S4R/S have the airbox & battery under the tank in the same spot and in the same configuration. I'm using the chopped airbox lid from my S2R on this bike (S4RT) so I know it's not because the airbox is bigger. Is the airbox deeper or does it sit higher? Not immediately understanding why the tank capacity had to be decreased.
2001 M900Sie - sold
2006 S2R1000 - sold
2008 HM1100S - sold
2004 998 FE - $old
2007 S4RT
2007 Vespa LX50 aka "Slowey"
2008 BMW R1200 GSA
S2R 800 '07
« Reply #11 on: December 09, 2017, 12:23:06 PM »
Larger heads  Wink
« Reply #12 on: December 09, 2017, 03:52:37 PM »
Huh?
~~~SNIP~~~
S2R and S4R, yes.
S4Rt/s is different layout of battery/ECU/etc and different airbox
