Belt Tensioner Sets
Started by motoyoyo, December 10, 2017, 09:15:29 AM
motoyoyo
I was looking for replacement belt tensioner bearings and pulleys recently and did not find any useful current information on any of the Ducati forums about replacement alternatives.  It has been a given for the life of these older Monsters that OEM was the only available choice.  I looked up the current prices at around $145 each for the fixed pulleys, 45110251a, and $25 each for the adjustale tensioner bearings, 45120201a.  This would be  around $390 for the full set of OEM parts.
I found an German company that sells aftermarket parts for all Italian bikes, marrocco4speed.de/ .  They also sell their parts on ebay, which is where I purchased my full set of tensioner pulleys and bearings.  The current price is only $129 for the full set of parts.  As far as I can tell, these are from the actual OEM supplier as well and should be of top quality.  At any rate, I am giving them a try and thought I would pass on this information as an alternative to the expensive OEM parts.
2007 S2R1000, 2008 KTM 990 SDR, 1998 BMW R1100S
They got a lot of stuff there. Lots of service parts.
Good find.
motoyoyo
Yes, pretty specific to tuneup wear parts.  I was mainly happy to see the pulleys, since they keep getting pricier through Ducati.  Hope this helps others.  I'll post back if I run into any problems with the parts, but don't expect to.
Langanobob
Thanks for posting this.  Those are SKF Made in Italy bearings - good quality and they probably are the same as OEM.
BK_856er
The bearings on the bolts are Flennor brand, but the others are marked SKF.  Is Flennor an OEM?
BK
motoyoyo
Flennor is a German Parts distributor that sells auto and motorcycle parts
BK_856er
Good to know.  In some of the other images the bearings are laser engraved with the Flennor name, so more than just a distributor.  Let us know how you like them.  Big $$ savings for sure!
BK
chipripper
2008 S2R1000 black and white, mostly stock ;-)
Marving header, Velocity stacks, Pod filters, Flashed ECU to DP map, Polished valve covers and cam covers, SSR reverse shifter and inspection cover, Aelle adjustable pegs, Windscreen and cowl removal, Many plastic bits removed, Cut beer tray
motoyoyo
That's a good question.  They may have some part numbers mixed up.  According to their website, this part is for the S2R800 but not the S2R1000.  However, according to the Ducati OEM parts fiche, both the S2R800 and 1000 use the same part, OEM# 451.2.020.1A
The 695 and others listed for this part take an OEM# 451.2.017.1A  They have something wrong with their cross referenced parts.  Apparently the part shown does not appy to the S2R800 or the S2R1000, and I don't see any other options for the complete adjustable assembly.
Hopefully the bearing set I ordered for my S2R1000 (shown in first picture) will fit.  I'll update if they work out after I get the parts.
