Ducati Monster 2002 S4 Front Brake Leaking
Started by Commachio, December 15, 2017, 07:47:37 AM
Commachio
Hi guys......totally new to this site and forums so hopefully I'm starting a thread in the right place.
I'm also new to Ducati and bike in general even though I passed my test in the military in '89.
So....hears my problem.
I was tuning in a concave driveway and unfortunately dropped the bike  :( do aks it's embarrassing enough as it is.
Anyway, only damage is that the rear brake lever is slightly bent (I.e. Brake light constantly on) so repair is in hand.
The main issue is that, since the drop, the bike has been in the garage. Today I started up for a quick ride and front brake was not doing it's job - took a couple of pulls before it started working. I've now noticed the brake fluid reservior has dropped. There also appears to be a wet patch in the garage.
Is there a way of determining where the leak may be? Or should I take it to the garage and relinquish my hard earned cash?
Any help would be appreciated.
Regards
Gazza
Welcome  [Dolph]
The rear brake lever/pedal can often be bent back. Front brake leak is bad - don't ride it. Even if you find the leak and fix it yourself, there will be air in the system - a situation you'd have to be skilled to fix.
I'd have it transported to a garage - maybe one that will allow you to watch (and learn). If no parts must be replaced, it shouldn't take (much) more than an hour.
Commachio
Okay....noted and many thanks. Off the the garage it is 😀
