Ducati Monster 620 Wire Harness / Bike Running Problems
Started by 2 Wheel Wanderer, December 16, 2017, 11:37:06 AM
2 Wheel Wanderer
Does anyone know if there is a difference between a 2005 and 2006 Monster 620 wire harness?
Thanks
Check the part numbers (ducati.com -> 'menu' -> dealers and services)
If they are the same = ok
If they are not.... find out why and if it's important (easier said than done)
2 Wheel Wanderer
Thanks Stopintime, yeah I checked em,
04 and 05 have the same part #, 06 is 1 number higher at the end
04,05  510.1.179.4A Electric wiring
06       510.1.179.5A Electric wiring
Looking at other part numbers they both use the same ecu  but have different part numbers for the dash panels
05 406.1.026.2C Complete instrument panel
06 406.1.033.5C Complete instrument panel
maybe a different pin configuration at the dash
When I got my new S2R800 dash, the dealer ordered '06 instead of '07. I had it adjusted to show correct mileage, by SOS Diagnostics, and THEN discovered the '06/'07 mix up. Too late. The difference on my bike is that the maintenance signal comes on after 10,000 km instead of the 12,000 which is correct on the '07. The '06 doesn't show travelled distance since the low fuel light comes on. Not the end of the world and an example of how insignificant any changes can be. The 620 changes could be more important.
The same ECU is a good sign, but you need to study the wiring diagrams very carefully to see if you can spot the differences. Maybe check the Owner's Manual first to check for dash funcionality changes first? (like those small things that I have)
Isn't it possible to get a correct harness?
2 Wheel Wanderer
Excellent find!  [clap] Thank you!!
Here is some background on my bike. Long post here.
Forgive me if I'm a bit all over the place in writing all of this down.
I've got an 05 620 with 85K miles on it.
Problems with the bike.
1.Over the years I've had to keep raising the fuel trim on my DP ecu to tune it correctly at idle (it's got Termis and open airbox). I've had it as high as 32 but after replacing the TPS and air pressure sensor this year it's been around 22-25. I've also replaced the CPS, engines(had a spare from a great deal I got a long time ago) and other parts.
2. Sometimes this bike feels great. Smooth, good power without effort. Sometimes some of the power goes away and the bike gets real vibey and jerky on/off throttle. BIGGEST PROBLEM
3. When tuning (with TechnoResearch software and a Gunston Gastester) with valves properly adjusted exactly the same, TB synced and both are bleeds screwed out the same amount idling at 1050-1100 rpms the reading is almost always the same. Vertical at 3.5% and the horizontal 8.5%. Every once in a while the CO's would read the same. Years ago they were always really close together.
FYI no fault codes, at least not with VDSTS software. It might be different with Ducati Mathesis at the dealership. I may take it there just to see what there machine says.
To me what it's come down to is either there's problems in the harness, the dash or the ecu.
I went the cheapest route 1st. I said screw it, took out my wire harness and started to dig in. I found a bit of white corrosion? on a section of wires that go to both coils and the vertical injector, right in the problem area. There are 4 wires that go into one(don't remember what the 4th goes to). I tried to desolder that section but that wasn't happening so I cut it out. All 4 wires were clean, nice and bright under the insulation. I cut off some of the insulation on the single wire and I find black strands. Not good. I cut it back to clean wire and soldered everything back together.
I get it back in the bike and give it a tune, lo and behold I had lower the trim to -1 the to get the right CO. Cylinder CO's were still far apart though.
So after the tune I'm hoping I have fixed power problem.
Nope, I go for a ride and it's OK but the power problem still exists. I'm thinking I might have more problems in the harness given what I found.
Anyway I bought a harness from an 06 M620 with really low miles for a good deal.
After hooking everything up and turning the key, the fuel pump primes and the gauges sweep but no neutral light, oil pressure sensor light or temp(only dashes). I hit the starter but I got nothing.
I replaced all fuses inc the 40A, switched out the relays, I compared pins to the engine side of the ecu and all were the same. I'll compare the body connector side of the ecu and pins to the dash to my old harness tomorrow. If those are OK I'll put in my old harness to see if there is a problem with the new harness.
Anyway, that's where I'm at. Sorry for the long post guys but I thought I'd put it out there to see if anyone has had similar problems and/or solutions.
Any help is appreciated, please feel free to ask questions.  [thumbsup]
I really wish I knew my electric stuff, but I don't. Hopefully the wizards will chime in. One thing I often hear is to check ground connections.... one from ECU to ECU bolt and the engine to frame bolt(?)
2 Wheel Wanderer
Quote from: stopintime on December 17, 2017, 01:28:37 AM
As soon as I read this my heart sank. I knew it was the ground wire to the engine that I forgot. I placed the wire where it needed to go but didn't bolt it in. I moved on to other connections.
It's 3am, I just went out to the garage to bolt it to the frame and turn the key. What do you know, after the gauge sweep the neutral light, the oil light and temp on the dash said LO.
I'll start it up in the morning and go from there.
Thanks stopintime, I can't tell you how relieved I am. I'll sleep a lot better tonight.
... and what do you know - I can now add 'have given helpful electrical advice' to my list  [laugh]
Quote from: stopintime on December 17, 2017, 03:50:47 AM
[thumbsup]  You don't need to be an expert to give good advice, just a good idea.
Langanobob
... and what do you know - I can now add 'have given helpful quantum electromagnetic theoretical electrical advice' to my list  [laugh]
FIFY.  Furthermore...you accomplished this remotely.  From I think the North Pole?
Quote from: Langanobob on December 17, 2017, 07:45:03 AM
Close enough  ;D
2 Wheel Wanderer
Hey all, just wanted to reply with why my bike sometimes ran well and sometimes ran poorly.
It definitely improved after putting on the new harness due to burnt wires in the old one but there was still something wrong. After riding through the winter I decided to dive into this again. I have a buddy with an S4 with basically the same gauges as my bike. I figured out how to disable my immobilizer and get his dash to work on my bike. I went out for a ride and that was it. It fixed the problems I've been chasing. The bike ran just like it used to, like it should.
10 years ago I had to get the dash replaced under warranty cause the bike was dying on me. I figured this might be the problem this time but couldn't test it and I'm not paying Ducati $135 and hour to do so.
I have a line on another dash but wondering how does the dash affect how the bike runs? Out of curiosity I've been looking for dash schematics online but cant find any. Didn't think I would but thought I might get lucky.
Anyway I just thought I'd let you guys know the outcome. Maybe it'll help someone else.
Have you tried riding without the dash?  I don't know how or if the dash affects how the bike runs - didn't think it did...
