April 28, 2024, 12:43:22 PM
S4rs Gauge circuit board question
Topic: S4rs Gauge circuit board question (Read 1407 times)
darkduke
'07 S4rs
April 24, 2018, 08:14:42 AM »
Had a bad day in my garage the other day... lets just say there was an incident and in the end my gauges are smashed.
But... the circuit board is still good and the bike runs and starts normally
So here's my question. (And yes, I've been using the search for two days now
Can I pull the circuit board from my original gauge cluster and swap it into a new one and not have to worry about flashing my ECU?
Thanks in advance
-ZG Windscreen - Pazzo Levers - CRG Lanesplitters - Arrow Steering Damper - Retro Tank Logos - Tail Chop - Speedymoto Clutch Cover, Springs, Caps, DP Carbon Rear Hugger, DP ECU & Open Airbox with Chopped Titanium Arrows
booger
Re: S4rs Gauge circuit board question
April 24, 2018, 09:10:27 AM »
I'd say with 90% certainty that if the bike starts & runs fine with the gauge housing broken, then the electronic innards are OK and working. If that's true then all you need are new plastics. Of course, those things are designed to discourage tampering & whatnot so actually making the swap could be easier said than done.
If your DP ECU wasn't married to the clocks when installed, you can just buy a used cluster off eBay and plug & play.
Last Edit: April 24, 2018, 09:12:59 AM by booger
2001 M900Sie - sold
2006 S2R1000 - sold
2008 HM1100S - sold
2004 998 FE - $old
2007 S4RT
2007 Vespa LX50 aka "Slowey"
2008 BMW R1200 GSA
thorn14
April 24, 2018, 09:45:33 AM »
Should be a straight swap.
I'd confirm the needles sweep properly, and read correctly as they are a PITA.
M620
turned
M800
but then back to M620 after the M800 died at 110k, and now to Multi 1000.
darkduke
'07 S4rs
April 24, 2018, 10:24:40 AM »
You guys are making me feel better already
Here's another question that I'm sure has a very definitive answer...
Seeing as how I'm already running the DP ECU; Would a 749/999/St3/sport classic set of gauges also be plug and play? I notice the connection is th same
Last Edit: April 24, 2018, 12:10:03 PM by darkduke
thorn14
April 24, 2018, 12:07:45 PM »
You should be able to use almost any case from the monster line, with the only differentiator from 2002-2007 being the center plastic piece color and design iirc. Or at least that was my experience with a 2002 620, 2005 620, 2006 s4rs dashes. If you wanted to use the insides from the donor as well it'd be another story.
M620
turned
M800
darkduke
'07 S4rs
April 25, 2018, 05:49:40 AM »
Ok, thanks. I'm guessing that would also include the Sport classic line as well.
I was wondering if a stock unit from a 749/999/St3 would work. Has anybody tried this? I realise the mounting is completely different, I'm not afraid to tackle that part of it. But I noticed the harness connection is the same, but I have no idea if the system is compatible.
April 25, 2018, 06:23:25 AM »
3 different cases AFAIK, early ones were glued together.
At some point, the cases were changed to a screw-together.
~2005 or so the cases and circuit board changed again, or a second case was introduced alongside the first.
If your immobilizer has been deleted, you could possibly make the 749/999/St3 work.
Stuka Pilot
April 27, 2018, 04:42:41 AM »
Do you wish to elaborate on the incident that resulted in smashed gauges?
darkduke
'07 S4rs
April 29, 2018, 08:00:13 AM »
Long story short.... I screwed up and my monster fell off its work table.
