Wiggle on the side stand (now a little make the beast with two backs! )
Started by stopintime, May 16, 2018, 01:40:10 PM
Has been slowly developing for two (three) years....
Last spring: shop took out the lower bolt (bracket to cases) and removed some old heli coil - cleaned threads and bolt - new heli coil and put back together. Quite firm and stable then.
Now it's wiggling again. I tightened the bolt, but it doesn't 'take' and feels 'soft'. Quite sure it's not possible to tighten well.
Is time sert my only option now? Ok to do that? Cases thick/tough enough
Late 90s cases from an SS. 6-7-8 mm spacer between cases and bracket. Don't know the length of current bolt (not extremely short)
You'll need to go bigger than a standard Timesert, as those are actually a whisker smaller than a helicoil.
The 'boss' on the cases is ~22mm diameter (0.866") on the exterior.
I do not have a set of naked cases at hand to measure the boss on the interior.
M10x1.5 Regular Timesert
Tap diameter 0.474"
M10x1.5 BigSert
Tap drill 0.484" (0.010" bigger than M10x1.5 Regular Timesert tap diameter)
Tap diameter 0.552"
Gives you ~4mm wall all around.
Like this:
https://www.amazon.com/dp/B003QB1A7C/ref=sr_1_1?m=A2N5EWWITZXTMB
There are other manufacturers of solid inserts, but Timesert seems to be the one that's focused on using the least material.
Drill to remove old thread? Then tap? Big Sert other manufacturer than Timesert?
I'll ask my shop to do it, but need to know a little about the procedure to order them about specifics.
I dont know if you have a Timesert specialist available, but I use a guy who only does that, day in day out. I explain the job to him and its parameters and he does it on site. I like the idea that its his specialty as he knows the product inside out and all its applications to tricky jobs.
Quote from: koko64 on May 17, 2018, 03:06:35 PM
Doesn't sound like the Norwegian job market. At all.  :-\
, but.... I don't need a sert specialist. I have a Nick  [thumbsup]
Quote from: stopintime on May 16, 2018, 03:02:34 PM
Drill, counterbore, tap, install insert.
Don't drill any deeper than the hole is already.
Be careful when the tap bottoms out.
Excess torque can crack the case, allowing oil access to the back side.
Not the end of the world, but unnecessarily added aggro.
Hold as steady as possible while drilling and tapping.
Drill bits that size can be uncooperative in hand drills.
TimeSert is the parent company, and it's also the name of their standard product.
BigSert is their larger outer diameter product, gives you a second bite at the apple.
They sell individual inserts and complete kits with the drill and tap, etc.
For a threaded hole repair done by hand, there are none better.
If you can hold the part in a milling machine or nice drill press, HeliCoils can be successful.
TimeSerts install real nice that way, too.
There may be a similar product that's local to you.
I'm not aware of how far they are distributing the product.
There are other manufacturers of the larger outer diameter solid inserts, they're more agricultural/stationary equipment :
https://www.ezlok.com/threaded-inserts-for-metal
Parts and kits are available locally and online. I'd prefer my dealer to offer this service, but I might have to buy a kit and do it myself. That will be the start of my new Time-sert specialist carreer - or not  ;D
This ok?
https://www.mechanicstoolsandbits.com/big-sert-5015-m10x1-5mm-oversized-metric-thread-repair-kit.html?search=big-sert&page=2
Ooops... do I need a tap guide and a T-handle wrench as well?
Yes, that's the standard kit, and it's fine.
You'll need something to turn the tap and the install tool.
Some tap T-handles have a standard square drive (like sockets), should be 3/8" drive in this size range.
The drill and counterbore tool will need a 1/2" capacity drill motor, which most folks don't have.....
The drilling is the truly uncooperative part, that would be the one to most benefit from a guide.
The tapping is a slow process, so there's plenty of time to make sure it's straight, and you can correct as you go.
The largest drill bit I can fit in my 12 volt drill, is 10 mm. Not enough?
It's over 12mm diameter with the tap drill.
You may be able to get a reduced shank on a 31/64" drill.
The kits seem to contain 14mm inserts + minimum 6mm margin for the installation driver = 20mm
Is that hole 20mm deep?
Is it deeper... enough depth for 20mm inserts + 6mm margin?
I've measured a few cases and I get 26-27mm depth for the holes.
Quote from: Speeddog on May 30, 2018, 12:18:36 PM
Thanks!  [thumbsup]
 [bang] [bang] [bang]  /    :-\ :-\ :-\  /    [coffee]
Big-Sert time today.
Worked well for a while, but I made a bad decision.
It seems someone machined a lot of the outside 'boss' and it's not deep enough for the 14mm insert + 6mm installation driver margin. I didn't think about that as a problem until I checked the tap and how deep it is. Deeper than the insert.
So I was missing a margin for the tap and the installation driver.....
So, what the hell do I do?
How thin can the cast cases be?
Too thin is the answer.
I drilled another ~3mm. No problem. Counterbore ok. Made threads with the tap. Installed the insert: light resistance at first, then harder for a couple of rounds and then light again. All as described. Remove installation driver...
OIL  :o
Side stand and screws back together. No visible oil after riding an hour.
Some Helicoil left overs
Can you see how the 'boss' is almost gone?
Back together, very much better than it was and still dry
