Torque spec for belt tensioner pulley [conflicting info]??
Started by chipripper, May 19, 2018, 12:53:24 PM
chipripper
The torque values thread lists:
Idler/tensioner pulley mounting stud  M20x1  50  45  55  LOCK 2 or THREE BOND 1324
I feel like I am going to strip threads before my wrench clicks. I noticed the ChrisKelly video for the DS engine said 20-25 ft lbs (@33.9 NM). I set it to the 25 ft lbs, and it felt "good and tight". Which setting is right, and what would Y'all do?
2008 S2R1000 black and white, mostly stock ;-)
Marving header, Velocity stacks, Pod filters, Flashed ECU to DP map, Polished valve covers and cam covers, SSR reverse shifter and inspection cover, Aelle adjustable pegs, Windscreen and cowl removal, Many plastic bits removed, Cut beer tray
I don't think that spec is for anything on your bike.
Can you post a pic of which screw or red arrow in a screen grab pic or ? ? ?
chipripper
The two silver ones that hold the tension adjustment pulley.
greenmonster
I`ve used 42 Nm and 222 Loctite on my 900`s. Did not feel like maltreating threads. Always worked, dozens of times.
M900 -97
MTS 1100s  -07
