Great Monday Morning
Started by bdfinally, May 21, 2018, 08:09:37 AM
bdfinally
Had to push it the last 4 blocks to work. My commute is just less than 2 miles. Ran fine when I cranked it at house and actually sat idling at a store on the way for a few with no problems. At mile 1.5 it started sputtering, coaxed thru a busy intersection pulled up on sidewalk and changed plugs. Cranked fine and idled well. Took off and as soon as got into 2nd sputtering started again. Slowed and eased it another 3 blocks to my turn and then she died. Anyway we've had about 8 inches of rain from the middle of the week thru saturday afternoon. It sat outside, uncovered. I'm thinking (hoping) my drain line in the tank is blocked again and got water in the tank. Thoughts?
Edit to add '00 carbed M750.
bdfinally
Quote from: bdfinally on May 21, 2018, 12:19:25 PM
Thanks Nate.
Use the float bowl drains to check and see if there's water in the bowls. If there is I'd drain the tank. Dry gas doesn't do much anymore because there's already ethanol in the fuel. I'd still use a small amount as it's a different alcohol.
bdfinally
Reviving this thread because I never resolved the issue (life got in the way [bang]) Drained the tank & bowls no water in either, but put fresh gas in regardless. It cranked but after a few minutes of normal idle when I tried to ride it it would again spit & sputter. This weekend the monsoon has given us a break and I've torn it down to the carbs. When I removed the pods and bottle years ago I routed 2 lines back behind the battery box to find quiet air. The two red lines off the carbs I put together with a T-fitting and those are still snug and in place. The yellow line was completely loose, but damn if I remember where it fits into the system. The parts manual as you can see isn't a lot of help. Anyone have an idea where and if this would lead to it's behavior? Thanks in advance.
The yellow line can hang out with the red lines any way you like.  It is also a vent line.
bdfinally
Thanks Howie. Yep, it was routed with the other one back behind the battery box. I was wonder where the vent was and think I found it between the linked carbs. Correct? The hose was totally loose when when I started looking at it the other day. Would that have caused my initial problem?
 If it starts on choke then dies down the road issues like a faulty vacuum fuel tap and kinked tank breather lines come to mind. If it has a vacuum tap the done thing around here is replace it with a manual tap. Be interesting to see how much fuel actually gets to the carbs. The stock carbs drain screws are useful there. How well does the filter flow? I had a filter that looked clean but only let a drop through at a time.
A suspected fuel pump failure can be bypassed and the tank filled past half to test via gravity feed. You would be pretty unlucky as the pumps are quite robust.
bdfinally
That morning it started, warmed up & was ridden about 1.7 miles without a hitch, then it suddenly started to act up. I think it's the vent line off the carbs stuck in the middle of the bank, under the fuel inlet. I just pulled the carbs off the manifolds & struggle for 1/2 hour to get the line back on with a hose clamp this time. That sucka gets a new colorful name every time I fool with it.
greenmonster
Kinked short fuel line under tank?
Tank vent ok?
M900 -97
MTS 1100s  -07
