Anyone modify Bazzaz to work on Monster S4R?
Started by sxspdlgnd, June 11, 2018, 10:43:36 AM
sxspdlgnd
Looking for advice on modifying Bazzaz to work with 05 Monster S4R...Kit is for S4RS..Everything connects except the coli connections.
Depends if those models use the same or different motors and ECU's. There is the older S4R with Desmoquattro motor and the later S4R with the Testastretta motor used in the S4RS. Which S4R do you have? Have you checked with Bazzaz if the device will work on the S4R with the correct hardware changes and operate with the correct software? I have not seen the S4R listed on the Bazzaz website. The later motor arrived in the S4RS in 2006 iirc and S4R models may have recieved the later motor by 2007. Someone here will confirm.
Quote from: koko64 on June 11, 2018, 02:03:50 PM
His 05 has a Desmoquattro.
