February 03, 2025, 05:47:07 PM *
News: Please Help
Author Topic: 2014 Monster 1200S fuel quick connector issues...  (Read 1041 times)
nickbee
« on: June 15, 2018, 10:33:20 AM »
Hey guys...
I lifted my tank for the 1st time to day to replace my air filter.  plastic fuel quick connector is leaking after.  I just inspected the fitting by turning on the key and letting the fuel pump cycle.
I inspected the O rings on the connector and they look fine (this was the 1st time they came off) and I coated them with silicon before reassembly.
Any ideas?  I've seem metal fuel connectors available for older monsters.  But none for these...
THANKS!
nickbee
« Reply #1 on: June 15, 2018, 11:12:56 AM »
never mind what I said... the top black o ring in nicked  Lips Sealed Lips Sealed Lips Sealed
Do we have a source for these?  Ducati parts are only showing the entire fuel line.  The o rings or even just the connector is not listed.
2 Wheel Wanderer
Pavement Junkie
« Reply #2 on: June 15, 2018, 01:39:54 PM »
Maybe give Ca Cycleworks a call, these might fit
http://ca-cycleworks.com/ca-cycleworks-products/gaskets-o-rings/misc-gaskets/or-17030
nickbee
« Reply #3 on: June 15, 2018, 07:06:58 PM »
Thanks!
I ordered viton rings from:
http://www.theoringstore.com
Do you guys have any tips on installing this connector without jacking the o rings? I’ll give them a light coat of silicon grease.
Also are there any metal quick connect conversions out there for this bike?
Thanks again!
« Reply #4 on: June 15, 2018, 07:33:34 PM »
Check with Motowheels
BK_856er
2007 M695; 2004 749s
« Reply #5 on: June 15, 2018, 09:47:24 PM »
Just grease the orings lightly before assembly.  Be prepared to replace if they've been on there a while.  The grease can dry out causing the oring to stick and tear when disconnected.  The orings can also take a compression set and harden over time.  I normally  use a lithium grease.   Viton is a good material choice.  Cheap insurance to replace the orings if you need to disconnect and it's been in place for a few years.  The plastic connectors can also get brittle over time and break when you squeeze them to release.
BK
