December 22, 2024, 05:59:01 AM *
Author Topic: BST replacement front bearings... OEM?  (Read 1741 times)
S2R 800 '07
« on: July 17, 2018, 07:35:21 AM »
Shit - I'm 2,000 miles from home with busted front wheel bearing(s).
Tried calling Motowheels (also emailed) to get advice on the question: 'OEM Ducati bearings ok'. Not open/not available....
I can get it fixed in a day or two if OEM works...
« Reply #1 on: July 17, 2018, 07:59:39 AM »
The OEM bearings are probably SKF.  Anyway, they can be crossed referenced to another brand.  These guys  https://www.allballsracing.com/  are reputable can supply you probably as quick as Motowheels if you can't find bearings locally.
S2R 800 '07
« Reply #2 on: July 17, 2018, 08:33:32 AM »
Thanks Howie - the question is specifically if the bearings in the BST wheels are equal to OEM.
S2R 800 '07
« Reply #3 on: July 17, 2018, 10:23:29 AM »
Stephano at MotoWheels measured a bearing from BST they had and those measurements are equal to the OEM 70250451A/SKF 6005 2RS . If that info is correctly understood and communicated....
« Reply #4 on: July 17, 2018, 11:58:14 AM »
6005 is the industry designation of the size, 25mm x 47mm x 12mm (Inner diameter x outer diameter x width)
2RS means it has 2 rubber seals.
That is indeed the designation/size of the OEM 'large axle' front wheel bearings.
« Reply #5 on: July 17, 2018, 03:40:41 PM »
How did I miss BST?
WTSDS
« Reply #6 on: July 19, 2018, 03:21:14 PM »
>>>How did I miss BST?
I thought he meant "Best", I.e. are there better bearings than OEM.
S2R 800 '07
« Reply #7 on: July 21, 2018, 12:36:25 PM »
Took a while to get them, but they fit  waytogo
I missed my train from Vienna to Hamburg today because of the delivery delays and am forced to ride the distance (I think Italians just don't see logistics as a worthy excerzise)
Heading home tomorrow, from Cortina to Kiel, Sunday 500 miles,  Monday morning 250. Ferry to Oslo and home Tuesday.
 Dolph
I'll make a picture report later.
« Reply #8 on: July 21, 2018, 02:24:26 PM »
 waytogo
Online Online
« Reply #9 on: July 21, 2018, 04:00:24 PM »
Glad you got it figured out Lars.
