February 07, 2025, 08:20:55 AM
S4RS 2007 now hard to start
Topic: S4RS 2007 now hard to start (Read 882 times)
dbran1949
2007 S4RS Black Termis
August 20, 2018, 03:23:48 PM »
The bike hasn't had a lot of use in the last few years as I have been traveling for work. I even had it shipped up to Portland OR for a while thinking i would be able to get some riding in but it rains a lot there
Anyway the bike always used to start with just a touch of the starter button, now it will go through a complete cycle of trying to start until the ECU times out, then starts on the second try. Hot - Cold same problem
Battery is always on a trickle charger, recently changed the plugs but that did not help
I am afraid i have gunked up the injectors from the lack of use -
Is there anything i can do to trouble shoot?
thanks
Dan
Re: S4RS 2007 now hard to start
August 20, 2018, 03:59:07 PM »
Since the bike has been sitting a while i would suspect either a fuel quality issue, battery or both.
Battery is easy, fully charge it and have it load tested. Fuel? Empty tank, while you are in there, new filter. A new set of spark plugs might help too. It may take a tank or two to see results. Some Techron or Seafoam is a good idea too, but no more than recommended. Still not good? Post back and we will talk diagnostics.
itsamonster
August 25, 2018, 12:32:44 PM »
Mine never starts first time from cold when it’s been stood even for just a week. It doesn’t time out on the starting cycle, but cranks over a few times and sort of wheezes and gives up. Then the rest of the day it’s good as gold.
I changed the starter sprag ( one way clutch)about 4000 mles ago because it wouldn’t engage and start.
Whats the mileage on yours? Mines on 16000 miles.
Last Edit: August 25, 2018, 12:47:47 PM by itsamonster
