April 27, 2024, 05:18:22 AM
M750 Scrambler Project
6
7
8
9
21
Topic: M750 Scrambler Project (Read 55755 times)
amcjen
Re: M750 Scrambler Project
Reply #90 on:
September 25, 2018, 09:52:36 PM »
Good stuff! Looks right at home on that trail.
Reply #91 on:
September 25, 2018, 10:20:21 PM »
Quote from: amcjen on September 25, 2018, 09:52:36 PM
Cheers.
Last Edit: September 26, 2018, 02:07:44 AM by koko64
greenmonster
Reply #92 on:
September 26, 2018, 04:09:14 AM »
15/41 is standard gearing for 750, I usually buy 750 chain/sprockets package for my 900.
M900 -97
MTS 1100s -07
Reply #93 on:
September 26, 2018, 07:26:22 AM »
You've got too heavy a bike with too little grip to do these sorts of lean angles on dirt, but they're illustrative of body position.
Having a bit less success with the corner entry photos, bike and rider position looks odd and generally not photographed much....
Mid corner, right elbow bent a lot, body near upright, inside leg up and forward
left corner mid sumo YZ-supermoto-extreme-lean
by
speeddog8308300
, on Flickr
If you Google 'roger decoster' images, he's nearly always in proper body position, and many of the pics are from the short-travel era, so more appropriate to riding a scrambler.
Reply #94 on:
September 26, 2018, 12:14:05 PM »
A Belgian Mick Doohan of MX. Thanks. The opposite elbow is bent down for corners. I only do that in a chicane at Broadford track (the esses). So thats normal on dirt? Ok.
It's like I've boxed all my life and taken up wrestling.
Last Edit: September 26, 2018, 06:07:28 PM by koko64
Reply #95 on:
September 27, 2018, 05:54:27 PM »
Just weighed and compared components. Changing the pipes and battery, removing a disc, brake line junction and caliper, running pods, lighter mirrors, fairing and brackets and removing the seat cowl has dropped about 14kg. The Barkbusters, risers and alloy bar swap put back a kilo, so about 13kg net which is a 28 pound weight loss, half from right under the tank and 3 kilos off the front end. Not bad and noticable.
Have to say I'm glad I chose a 750 for this task as my modified M900 feels brutal on dirt roads and in the wet both power delivery and suspension wise. Wise guidance here prevailed. Cheers.
Last Edit: September 27, 2018, 06:04:19 PM by koko64
Reply #96 on:
September 27, 2018, 05:58:05 PM »
Nice. Bet the bike is real nimble.
Reply #97 on:
September 27, 2018, 06:12:32 PM »
Yeah, steers beautifully and in a predictable, linear fashion. Arcs quite smoothly through the apex of a corner with little effort.
It's a joy to ride. I can't get over how sweet the motor is.
Reply #98 on:
September 28, 2018, 09:32:37 PM »
Have you rode with a passenger yet?
Reply #99 on:
September 28, 2018, 10:45:35 PM »
Yes. The GLW has been on the back a few times now and it has been great. Between the upright riding position. lower pegs and custom seat the ergos have suited us. I have only ridden two up on paved roads so far. The suspension feels good two up on paved roads, but needs work for the trails.
Last Edit: September 29, 2018, 02:46:15 AM by koko64
Reply #100 on:
October 01, 2018, 02:43:16 AM »
IMG_1344
by
Tony Kokonis
, on Flickr
Since the SS guard didn't fit the tyre, this was the protection I settled for.
Reply #101 on:
October 01, 2018, 02:44:42 AM »
That'll work.
Do they come off easily to check for dirt that's made it's way in?
Reply #102 on:
October 01, 2018, 02:48:51 AM »
Yes, just Velcro on and off to wash them and check underneath.
Being soft neoprene they kind of squish up and down with the fork like a gaiter but are in contact with the forks like a skin.
Last Edit: October 01, 2018, 02:58:28 AM by koko64
Reply #103 on:
October 02, 2018, 04:08:59 AM »
I have no recollection of the jetting on my 750, but do remember using Dynojet needles with Factory Pro needle jets.. I also recall going richer on the pilots to make up for the seized idle mixture screws, going back to stock after finding used bodies with functioning idle screws. If my memory is correct our carbs were set leaner than yours. Cold running was ridiculous. Never got around to trying stock springs.
Oh, the main jets,needle and clip position was whatever Dynojet recommended for stage II.
Reply #104 on:
October 02, 2018, 04:24:54 AM »
6
7
8
9
21
