695 - Help Draining Fuel
Started by TightLines, October 07, 2018, 04:45:44 PM
TightLines
Have a Monster 695 that won't be ridden for awhile (no time and 1st kid on the way).
I'd like to drain the fuel but had a heck of a time with it today.
My first attempt was to remove the fuel lines from the gas tank but had trouble getting them off and started to realize that I'd likely be fighting fuel from coming out of one while I wrestled with the other line
Can you tell I haven't done this before?
I did a quick search here and on YouTube for a good way but didn't have any luck.
Any help is greatly appreciated.
Thanks,
Jordan
How long are you going to have it off the road?
TightLines
In all likelihood, a few years.....  Just don't feel a need to sell it.
OK, so more of a winter storage prep is the ticket.
There's folks from the East here that are knowledgeable in that.
TightLines
Bumping this up for anyone that can give me some pointers for draining the fuel out of this thing.  I'm getting desperate and riding it isn't an option (not registered and the fuel is already pretty old).
Thanks in advance.
BK_856er
I'd siphon out as much as you can, then remove the two lines by squeezing the connectors. Often the connectors are brittle and the orings might be stuck to the flange, so you might have to work at it and new connectors might be in order, or at least orings. To get all the fuel out you'll want to also remove the pump assembly. Good opportunity to shrink the tank back to size (takes time). Just winter storage? Don't bother draining just fill and add stabilizer.
BK
dk1six
Another tank draining option if you're set on doing it  that's worked for me is using a small electric pump and 1/4 " tubing for the suction line.  Amazon has one for $15 it's a quick and easy method to get just about all the gas out of the tank.
98 900 SSFE
05 S2R 800
07 Sportster 883L
20 Moto Guzzi V7 Racer
Or a male fitting and hose to a jerry can. Ignition on to purge tank.
TightLines
Thanks everyone for the input.  Definitely have a few new suggestions that did not occur to me.
booger
For long term storage:
1)need to fog the cylinders
2)clean the bike
3)coat chain & paint all fasteners with a corrosion inhibitor like Corrosion X or similar
4)drain the tank
5)change the oil
6)get the bike off its tires
7)cover it
8)remove the battery
May seem like a lot of work but will mean the difference between a bike that starts after years of stasis and one that will need to go to a specialist to resuscitate($$$). Also, will preserve its value.
2001 M900Sie - sold
2006 S2R1000 - sold
2008 HM1100S - sold
2004 998 FE - $old
2007 S4RT
2007 Vespa LX50 aka "Slowey"
2008 BMW R1200 GSA
