April 28, 2024, 12:08:23 PM
DS 1000 fuel line clamps
Topic: DS 1000 fuel line clamps (Read 1069 times)
PA DL
October 12, 2018, 05:47:52 AM »
Does anybody have a good way to open the fuelline clamps on a 07 S2R1K?
They looks like onetime use only.
PA DL
Re: DS 1000 fuel line clamps
October 12, 2018, 06:25:42 AM »
RB
October 12, 2018, 06:51:25 AM »
Probably Knipex clamps, you need the Knipex pliers to remove and reinstall, or just destroy with a screw driver and regular pliers, then replace with a new hose clamp.
S2R
FLAT ORANGE
PA DL
October 12, 2018, 08:38:52 AM »
I wanna run the feed an return line outside the aluminium beems and a short tube between the injectors. Any negative efects that I havent thought about if I do that?
RB
October 12, 2018, 09:39:51 AM »
Should be fine, as long as no kinks in the hose. Fuel injection just needs to build and sustain pressure, it doesn't care much about length or bends.
S2R
FLAT ORANGE
PA DL
October 14, 2018, 12:53:42 AM »
Thanks RB
October 14, 2018, 08:13:16 AM »
Don't let the line chafe on sharp edges.
Running pressure is 45psi, so leaks are serious.
