April 28, 2024, 03:00:39 AM
well I really wanted a Monster... I almost got one!
5
6
7
8
Topic: well I really wanted a Monster... I almost got one! (Read 28449 times)
buzzer
Re: well I really wanted a Monster... I almost got one!
Reply #75 on:
January 21, 2019, 03:20:22 PM »
The bike is now running, it sounds fantastic! I balanced the carbs with the vacuum gauge. I prefer to use a single gauge as its far more accurate… if ever you have a bank of gauges connect them up to a single vacuum source and check they are calibrated. most are WAY off! with a twin I simply use a “T” piece and clamp the pipes individually with a pair of pliers, alternating from one cylinder to the other… the clamp in the picture is to damp the needle on the gauge. Its a VERY accurate way of doing it… makes a huge difference to the tick over.
Below is the initial configuration of the Ignitech ignition.
buzzer
Reply #76 on:
January 25, 2019, 07:12:21 AM »
Well here you go, just a short clip... I did take it up a very short private road and it pulls well and sounds... LOUD, but awesome!
buzzer
Reply #77 on:
January 31, 2019, 10:55:29 AM »
As always there are snags on a build like this… I have always been worried about the head of fuel the carbs will get… it was OK with a full tank, but not enough to give me a reserve position on the tap. This was overcome by fitting a small electric pump, but this showed a weakness in the float needles in the carbs, Any leaks here is above the engine so I bought some new and genuine float needle valve assemblies and set the float heights to 14mm with a gauge I quickly made up. Easier to do if you clamp the float into position with a washer… no leaks after they were fitted…
Reply #78 on:
January 31, 2019, 01:38:32 PM »
bravo.
That map makes want to fit a TPS to my FCRs.
buzzer
Reply #79 on:
January 31, 2019, 04:07:28 PM »
Quote from: koko64 on January 31, 2019, 01:38:32 PM
bravo.
What ignition are you running? My experience with a car running 2d and then converting to 3d was chalk and cheese... the difference was amazing. Hence no hesitation going 3d with this conversion.
Reply #80 on:
January 31, 2019, 10:02:34 PM »
Im running an Ignitech V88. I have tuned it and the carbs to a level that is quite good, but of course there are some ways in which Im not getting the most out of the motor.
buzzer
Reply #81 on:
February 01, 2019, 03:12:45 AM »
Quote from: koko64 on January 31, 2019, 10:02:34 PM
I would say try a TPS... I have used the one off the Multistrada... I thinks I have seen that someone makes a kit to fit your carbs, but I cant remember where... it would not be too difficult to make something i guess...
I had a 150 BHP crossflow in a Westfied years ago... it was a manic car to drive... it had a 2D distributor on it, and did 20MPG... difficult to drive normally day to day, so much so my wife refused to drive it. I then fitted a 3D ignition, and it transformed the car! and the MPG went up to over 30 MPG! have a look here...
https://jtccc.wordpress.com/projects-2/megajolt-3d-ignition/
Last Edit: February 01, 2019, 03:46:17 AM by buzzer
Reply #82 on:
February 01, 2019, 03:45:11 AM »
FCR kits for some makes came with a TPS so getting those kit parts from the importer shouldn't be too hard.
buzzer
Reply #83 on:
February 02, 2019, 02:10:01 AM »
A couple of pictures under the seat…. the alloy rod is the tank stay velcro holding it in place!
wiring is nice and simple on this one! I mounted the ignition module on stilts with small rubber feet ( i used the original ones from the multistrada clocks) to insulate it from vibration.
This is probably the last post for a while... I will update again once its been road tested...
anyone interested, this is the link to my blog, where I have my other projects...
But for now, the hunt is on for another project... I would like it to be another Ducati, but I am not ruling anything out! so if anyone has anything at the back of their garage gathering dust that they might sell... get in touch!
Reply #84 on:
February 02, 2019, 02:48:37 AM »
Very tidy
greenmonster
Reply #85 on:
February 02, 2019, 06:27:39 AM »
Very clean!
M900 -97
MTS 1100s -07
Reply #86 on:
February 02, 2019, 09:34:38 AM »
Impressive indeed!
pitbull
Reply #87 on:
February 05, 2019, 08:35:49 AM »
You have some serious build skills.
Beautiful job!
S2R 800 '07
Reply #88 on:
February 05, 2019, 10:54:50 AM »
That under seat arrangement alone is worth a ten
I'd like to see the rear light strip (?) moved to the seat cowl. Or under the frame. Let us see the frame!
buzzer
Reply #89 on:
February 09, 2019, 12:04:26 PM »
I managed to get the raw data from some Ducati ECU files. I have colour coded it to see the pattern of the values in a visual format (isn’t Excel brilliant!) Across the top is the RPM, and down the left is the TPS values, The lower values are throttle closed. these follow what I would expect to see on a 3D advance map. I hope to replicate these in the ignitech map on the bike. Just need some decent weather to ride it!
Last Edit: February 10, 2019, 02:18:10 AM by buzzer
5
6
7
8
