May 01, 2024, 02:53:46 PM
Fuel Tank 2000 Monster 900
Topic: Fuel Tank 2000 Monster 900 (Read 2558 times)
Allaband
November 04, 2018, 06:06:59 PM »
Hello, my 2000 Monster 900ie has a tank with lots of damage and Bondo. I bought it that way. Looks good but it was obviously an extensive repair. I'm starting to get gas smell and noticed some white crud on the bottom lip of the tank. I think the fuel is melting it's way through somewhere. I'd like to just get a good tank to solve this issue but I can't find one. I looked through the forum and it seems I can ONLY use a tank from a 2000 or 2001 Monster 900ie. ANYTHING else will not fit. I'm having trouble finding such a tank. Other tanks are $200 to $300 and that seems reasonable. If my dreams come true I'd like a black tank with no dents or rust. I'm guessing I can use all my tank internals and cap so I just need the tank. Can anyone help me with sources?
Thanks!
Re: Fuel Tank 2000 Monster 900
November 05, 2018, 02:13:49 AM »
Ducati Depot in US and Ducatishack in Australia come to mind.
November 05, 2018, 04:47:00 AM »
I believe any
steel
fuel injected Monster tank will work. There is a shape difference on the bottom of the 4 valve tanks.
Anyway, read on:
http://www.ducatimonsterforum.org/index.php?topic=541.0
Last Edit: November 05, 2018, 10:08:18 AM by howie
November 05, 2018, 08:37:30 AM »
The '00 and '01 M900 had a unique layout under the tank, with the upright wet-cell battery and 15M ECU.
I've checked my usual cross-model-fitment source, and it's telling me things that I know are not true (IE, '02 S4 tank = '02 M750 tank -> nope)
It *may* be saying that the later fuel injected tanks are back compatible to the '00 and '01 M900.
I'm skeptical of that, but have not tried it.
November 05, 2018, 10:28:24 AM »
For sure the 750 tank will not fit the S4. Other way around? Don't know
The only safe bet without having one to try is compare part numbers here:
http://www.ducatiusa.com/services/maintenance/index.do
excluding the last three numbers which designate color, ex. 1 586.1.031.2AB Fuel tank (BLACK)
How do I know about this?
http://www.ducatimonsterforum.org/index.php?topic=76793.0
Thank you Speeddog!
November 05, 2018, 01:53:32 PM »
I'm
pretty
sure that the fuel tanks are backwards compatible up to the plastic tanks. The fuel line locations are slightly different, but the tank bottoms are otherwise not visibly different.
Plastic will not replace steel.
herm
November 05, 2018, 03:34:31 PM »
Quote from: ducpainter on November 05, 2018, 01:53:32 PM
I'm
pretty
But steel
will
replace plastic!
November 05, 2018, 03:36:21 PM »
Quote from: herm on November 05, 2018, 03:34:31 PM
But steel
will
replace plastic!
It
can
...with enough pieces.
Allaband
November 05, 2018, 08:47:26 PM »
I was reading through that "all about fuel tanks" thing and I think it says I can use ANY monster fuel tank from 2002 to 2004. Is that true? That actually opens up A LOT of options for me. I have a few tanks to choose from if I can use ANY monster tank from 2002, 2003, or 2004.
Thanks again for all the info and help everyone!
cmross13
November 06, 2018, 01:49:07 AM »
i just got out of this same boat with my 2000 M900ie. all of my VERY thorough investigation lead me to just pay the premium and buy a near-new 2001 M900ie tank(still has the safety sticker below the fuel filler). shame im just going to strip it and recolor, but my dime i suppose lol
that being said, i bought my bike with two functioning but ugly tanks. i have a yellow one with a small dent but some rust inside that i think could easily be treated with CLR, POR15, or maybe even just sloshing fresh fuel around in it. for the right price i can have my body guy pop the dent, clean the inside, and spray it any color you like.
the other one has no internal issues, but two bigger dents. same scenario, im sure we could pull them and recolor it, if you want to pay the price for a like new tank.
i will be doing this anyway, and charging a bit of a premium for it as they will both essentially be "new" tanks paint to order.
2007 S4RS, 2000 M900ie
herm
November 06, 2018, 06:25:10 AM »
Quote from: ducpainter on November 05, 2018, 03:36:21 PM
It
can
Yes, yes.... Minor bits. Fuel pump, hinge, etc...
November 06, 2018, 08:57:43 AM »
There's a shop in Reseda that has a few different tanks that could be test fit on a bike to check.
GK
November 09, 2018, 10:45:14 AM »
But steel
will
replace plastic!
The riddle of steel!
Ducati
Monster
900S ie
Gone but not forgotten!
Allaband
December 29, 2018, 10:49:29 PM »
I finally bought a plastic tank. It was $250 and had the fuel pump and flange still in it. Luckily it just plugged in and worked! Unfortunately I'm left with two problems. The hinge at the back of the tank is quite different for metal or plastic. I'm looking all over ebay and can't find the hinge for a plastic tank. Does anyone have one or know where I can find one? The second problem is that my handlebars bump the plastic tank. I'm guessing this could be due to the tank not being properly mounted at the rear hinge. Any advice here would be helpful.
Thanks for all the advice and help everyone!
herm
Reply #14 on:
December 30, 2018, 07:13:06 AM »
The hinge for the plastic tank should be available from a dealership. I have a picture somewhere, and will post it if I can find it... Also, You are going to want to coat the plastic tank inside, if you haven't already.
Lastly, once you remove the hinge for the metal tank, the plastic tank will sit pretty close to where it belongs. If the plastic tank is used, it may have swollen enough for the handlebars to bump the tank.... Hope that is NOT the case.
