Ignitech on an EFI bike - ignition only
Started by buzzer, December 15, 2018, 04:26:02 AM
Quote from: buzzer on December 20, 2018, 07:28:24 AM
Thanks for that, I didn't know about that site.  is the difference between the 1000 and the 1000DS the DS has twin plug heads?
Yes.
buzzer
Update...  I sent the unit back to Ignitech...  It was delivered and signed for on the 2nd Jan.
I have emailed 4 times to ask whats happening, no response, no acknowledgement, nothing.
very very poor.
So whats my alternative?  anyone got a suggestion for another company who produce a similar unit?
Quote from: buzzer on January 10, 2019, 03:35:28 AM
very very poor.
I've been waiting for a company to put two shotgun firing pins in the mail since Dec 20. They claim they're busy. What's my alternative...make my own. I don't have a lathe.
I'm not aware of an alternative besides building your own. As I've said, ignitech won't leave you hanging.
buzzer
Where are you based?  If it's a simple job I could probably make you a firing pin for you on my lathe…
Quote from: buzzer on January 10, 2019, 04:08:53 AM
I'm in the US. I don't think either of us want to deal with the restrictions on importation of firearm parts.
Besides...life's circumstances has taught me patience. I suggest you be the same with ignitech. They'll get it sorted.
buzzer
yea, good point on the firearms parts  [laugh]
I am patient, its the complete lack of  ANY response that gets me...  A friend sent them a sales enquiry this morning, and they came right back...
I will give it a couple more days before I try to find and alternative and let people know what my experience with Ignitech has been like...  shame as I love the unit and software...
They're a small shop...two guys, I think. When they have some info I'm sure they'll get back to you.
I agree, it wouldn't be a big deal to acknowledge receipt of the unit. Good luck finding an alternative.
buzzer
they have come back to me finally....  let see...
greenmonster
#23
QuoteThe guys there sent we a unit already customised to run with a bike (1000 engine) using a hall effect sensor.
Quoteproves the inductive pickup is OK ( i did initially think it was a hall sensor but since found out its inductive...)
1. Confusing. Do you have an Ignitech for Hall sensor and your engine has an inductive?
2. In your first screenshot, shouldn`t "number of lobe at rotor" be 48? , on top first part.
M900 -97
MTS 1100s  -07
buzzer
update...
Ignitec received the unit back on the 2nd Jan.  took them till the 10th to reply to emails, but said the found nothing wrong?  said they had bench tested it.  I asked them to return it, which they did and it arrived yesterday.
today I plugged it in, connected it to the PC, and the first thing I noticed was the configuration of the unit still matched the configuration that was on the PC...  I then saved the file just to be sure i had a base file.
I then hit the start button, and it fired into life!  now in the mean time I have done nothing to the wiring on the bike...  so they must have done something, I have no idea what.  all is well that ends well though, and its running!
greenmonster
 [thumbsup]
Does the map you have now look exactly as in your first 3 screenshots on page 1 in this topic?
Downloaded any good DS maps?
M900 -97
MTS 1100s  -07
buzzer
Quote from: greenmonster on January 18, 2019, 09:56:55 AM
[thumbsup]
The bike is now running, it sounds fantastic!  I balanced the carbs with the vacuum gauge.  I prefer to use a single gauge as its far more accurate…  if ever you have a bank of gauges connect them up to a single vacuum source and check they are calibrated.  most are WAY off!  with a twin I simply use a “T” piece and clamp the pipes individually with a pair of  pliers, alternating from one cylinder to the other…   the clamp in the picture is to damp the needle on the gauge.  Its a VERY accurate way of doing it…  makes a huge difference to the tick over.
Below is the initial configuration of the Ignitech ignition.  I have the original 1000 DS map and a Ducati Performance map and will take a look and compare it to the Ignitech on in the next week and post up the results.
greenmonster
 [thumbsup]
The TPS 0%/100% voltage, default or measured by you?
M900 -97
MTS 1100s  -07
I wonder how much less advance the motor will like since it has twin plug heads.
Will you be playing on the dyno at all?
buzzer
Quote from: greenmonster on January 22, 2019, 12:19:48 PM
[thumbsup]
It was set by me.   You click the set button closed and again fully open. It appears to be linear.
