Double swing arm monster/non spool and pit-bull tand, rod thru wheel axle??
Started by Qomomoko, January 03, 2019, 07:32:46 AM
Quote from: Speeddog on January 08, 2019, 07:47:07 AM
My '02 S4 was 15/37 off the showroom floor, so 15/41 would be +4 links from OEM.
+2 links since half the sprocket isn't carrying any of the chain, no?
Qomomoko
41 on the rear makes 1st gear useful LOL
Did 102 links, now I see why you cant do 101 jejeje
Going to look into why the rear spins "tighter at one spot". The spot I go by the turning of the rear sprocket, degree X.
I will try and see how degree X correlations to what location of the chain might be tighter of if My sprockets are not aligned.
The slack was set. it calls for 25mm to 27 mm. At the tightest spot it measures 25.5 mm and looses it measures 28.5 mm
Pretty happy it but rather not ride untill I figure the rear beight tight.
Also, the parts that are missing, #18 and #19, so far no answer from the last shop that saw my bike :(
