December 27, 2024, 10:27:31 AM *
Pages: [1] 2   Go Down
Author Topic: Ohlins DU333  (Read 3146 times)
Derekv
« on: February 28, 2019, 08:24:26 AM »
New DU333 rear shock arrives tomorrow.  Still snowing here, so won’t be able to ride.  Plus out of the country for a few weeks.  I’ll get installed Saturday, if I can get the bike from the storage unit to the garage.....
Any advice on setting it up?
2005 S4R.  Just rebuilt the forks with new seals and oil.  All fork settings are at factory settings.
Derek V
2005 S4R
Online Online
« Reply #1 on: February 28, 2019, 09:21:36 AM »
Did you order it sprung for your weight?
Derekv
« Reply #2 on: February 28, 2019, 02:12:22 PM »
I wasn’t given any spring options.
Derek V
2005 S4R
Online Online
« Reply #3 on: February 28, 2019, 03:29:39 PM »
You might want to ask Speeddog.
How much do you weigh wearing your gear?
Derekv
« Reply #4 on: February 28, 2019, 05:22:55 PM »
165lbs + gear (~17lbs), 182 lbs.
Derek V
2005 S4R
Online Online
« Reply #5 on: February 28, 2019, 05:32:27 PM »
All I can say, is if the DU333 is sprung like the DU044 then it's a little light for your weight.
Ask Speeddog. He has the numbers.
That said, if you're happy with the stock front then you might be really happy with the Ohlins as delivered.
Derekv
« Reply #6 on: February 28, 2019, 09:03:42 PM »
Thank you.  I’m hoping that it works better than the stock Showa.  It isn’t like I am good enough to get 100% out of the stock suspension anyway.
Derek V
2005 S4R
Derekv
« Reply #7 on: March 01, 2019, 06:06:54 PM »
Got it installed.  Definitely changed the handling.  Quicker.  Only had time for a very short ride.
For ride height, should I adjust the spring preload first or the adjustable link?  I would think the link first because changing the preload will also change the handling, yes?
Derek V
2005 S4R
Online Online
« Reply #8 on: March 02, 2019, 04:35:42 AM »
Everything you do to a suspension will change the handling.
Set the preload/sag first. That's a basic setting, and IMO doesn't need to be fiddled with once set. Ride height is more preference.
If you get the rear too high, not only will the handling be extremely quick, but you'll discover any weakness in the front suspension as it will be loaded much more heavily.
« Reply #9 on: March 02, 2019, 08:21:36 AM »
A spring ~9.5-10 would be a good place to start.
Your spring should be marked, something like 1091-31/95 XYZ4.
What is your spring?
Unless you know *for sure* that your link adjustment is free to move, assume it's seized.
Either leave it alone, or remove it and fix it.
OEM fork springs for the S4R were pretty good for your weight.
Both ends will likely be fine on relatively smooth pavement.
They'll be harsh on sharp-edged bumps.
If you want to improve compliance, both front and rear will need to be revalved.
Lots of folks are good enough beer drinkers (whatever that is) to appreciate good beer.
Same goes for suspension.
Online Online
« Reply #10 on: March 02, 2019, 08:24:57 AM »
Seized link on a new shock?
« Reply #11 on: March 02, 2019, 08:40:20 AM »
No, the OEM pushrod.
AFAIK, all of them were assembled dry at the factory.
Online Online
« Reply #12 on: March 02, 2019, 08:43:22 AM »
Ahhh. I forget about that on the S*R bikes.
S2R 800 '07
« Reply #13 on: March 02, 2019, 09:11:26 AM »
+1  bang head
You should have seen my mechanics' knuckles when he adjusted mine. And his face when I asked him to turn it back to stock adjustment  Evil
Derekv
« Reply #14 on: March 02, 2019, 09:35:46 AM »
Thank you everyone for the help.
-Set pre load first.
-The spring is labeled; 01092-31/95- L1910
-My link adjustment connecting rod is an aftermarket part, it is free to adjust.  I have adjusted since installing it. I am planning to lengthen it 2 flats to take it up to where I can just flat foot the bike.
-Sounds like I’ll be loosening the front and rear settings. I either take it on local, flat and straight runs or up into the mountains and canyons of Colorado that it seems like it was made for.
Derek V
2005 S4R
Pages: [1] 2   Go Up
