Ducati Monster 1200 oil leak
Started by Aurora, March 06, 2019, 03:44:57 AM
Aurora
Ok Here is a new picture: https://imggmi.com/full/2019/3/7/d9933b81729fe728adb26add05e29367-full.jpg.html
I tightend the filter 1/4th turn with a filtertool and wrench.
I cleaned the lower part with "Bräkleen" and sprayed it with dry shamppo, i also put in a new original oilplug and a new aluminium washer instead of copper. its supposed to be softer and it looks like its tight at 20 nm wich the copper one wasnt.
It still looks like its the actual joint thats leaking :(  the lower screw looks damp in the picture but that was just a "miss spray" i sprayed it again and its dry there. i just didnt take a new picture. Whats my best bet? An enginge rebuild? :(
is it possible to weld it (professuily ofc) or is there some kind of...bond/paste/sealant i should try?
Is that actually a joint between the cases, and a removable cover?
Aurora
Yup. The cover goes to the "Oilscreen" im not sure you can reach the joint from inside ofter removing the screen and maybe add some kind of seal that way...
Aurora
This is afterlike 3hours. its clear that its the joint thats leaking. Kill me please and make it quick!
https://imggmi.com/full/2019/3/7/a999fbf38db8a90d9f746da1f022314e-full.jpg.html
So, the joint that's leaking is the case halves, or a removable cover?
You won't be able to add sealer by removing the screen
Replace the O-ring under that cover?
Before welding anything do two things:
    Change the O ring as suggested by stopintime.
    No torque wrench?  7/8 turn on the oil filter after initial gasket contact.
Cheap and easy first [thumbsup]
Aurora
Im takeing it to a local workshop. i wont spend another hour on my back in my cramped garage! :P
It doesnt come from the filter nor that cover you see. its the actual joint and its the joint between case halves and not removable :(
Sorry to hear. Hope its sorted soon.
Aurora
How about draining the oil for like 24hours. Cleaning with bräkleen and than a fat string of jb weld? Or is that a Quick Panic trepair for the moment?
How about the two or four closest engine case bolts? One by one, remove, check, reinsert and torque check.
Aurora
Thats a Good bet. My confidence tells me i shouldnt touch Anny bolts but om gonna ask the workshop to do it for me ðŸ˜,,
Aurora
DO you know the correct torque for them?
Aurora
Not sure this is the exact engine but it looks pretty close. Look for part 31 in the upper picture. looks like 2 scres is pretty close to the bottom where the leak is!
