April 28, 2024, 04:55:17 PM
5-6 neutral
Topic: 5-6 neutral (Read 1079 times)
arta302
5-6 neutral
April 09, 2019, 12:21:15 PM »
My 2018 797 Monster has 831 miles and I seem to find neutral when shifting from 5 to 6. Not every time. In a 3 hour ride made once or twice at most. If this have been covered I missed it. My first Ducati and will not be my last! I have been riding for about 50 years so I do not think it is rider error. It does change gears with the second try. Could it be that with brake in that will go away
Online
Re: 5-6 neutral
April 09, 2019, 12:41:46 PM »
I hate to say it, but it's likely you're just not being 'positive' with your foot. It happens to me, on occasion, as well although not necessarily with my Monster. Cost me a top end on my SBK.
If it were me, I'd try adjusting the shifter down just a little, if it continues to be a problem.
Re: 5-6 neutral
April 09, 2019, 01:42:25 PM »
The 5-6 gears are turning the nearest rpm, so any clash lasts longer, so more likely not to complete given the same input by the rider.
Just keep the pull on it until it goes in, the 'box just isn't slick enough to work reliably with a stab.
And as DP said, definitely give the mechanism/position a look and see if it can be improved.
arta302
Re: 5-6 neutral
April 10, 2019, 05:28:14 AM »
Quote from: Speeddog on April 09, 2019, 01:42:25 PM
Thanks I will look at the adj approach.
chipripper
El Borracho mas grandisimo
Re: 5-6 neutral
April 11, 2019, 07:48:20 PM »
Coming to my monster from a series of Hondas, this was the first thing I had to get used too. Being forceful with the gear lever, and gentle with the gas and breaks. Many false shifts and jerky starts the first week or so. Complete opposite of what I was used to. My old cb could be shifted with a thought, but you could hammer the throttle without consequence. Adjusting the shifter to the perfect spot helped me a ton.
2008 S2R1000 black and white, mostly stock ;-)
Marving header, Velocity stacks, Pod filters, Flashed ECU to DP map, Polished valve covers and cam covers, SSR reverse shifter and inspection cover, Aelle adjustable pegs, Windscreen and cowl removal, Many plastic bits removed, Cut beer tray
silas
2V
Re: 5-6 neutral
April 25, 2019, 10:00:23 AM »
"they all do that, sir". All my Ducks- 2 monsters and 4 '90's SS's have had the biggest accidental neutral betw. 4th and 5th gear. I agree a more positive kick into gear helps.
Quote from: arta302 on April 09, 2019, 12:21:15 PM
Ride fast, ride safe
'98 M900, '92 Yamaha TDM850
